A Find | Page 2 | FerrariChat
A Find
Discussion in 'Aviation Chat' started by Bob Parks, Nov 10, 2015.
  1. Rifledriver
    37,335
    At one time I saw a bunch of pictures of an airfield where P51 flight training for the ROK Air Force was taking place. Lots of Mustangs screwed into the ground upside down doing go arounds.
  2. ralfabco
    ralfabco Two Time F1 World Champ
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    How difficult is it, to take off with a P-51 ? What else is required besides full power, holding the stick all the way back, and keeping it centered on the runway with rudder inputs ?
  3. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,018
    Shoreline,Washington
    Robert Parks
    #28 Bob Parks, Nov 23, 2015
    From what I learned; Throttle is applied gradually or you might meet yourself coming the other way. Right rudder trim should be set and as the throttle is increased, your right leg should get longer and stronger . The stick should be forward a bit to get the tail up so that it has some airflow to maintain more effective directional control then gradually come back on the stick when the correct airspeed is reached. Let the airplane leap into the air and climb out to meet the enemy. Mike G. or Sparky should chime in as the experts, I'm not.
    One of the most frightening take offs that I ever witnessed was at Renton years ago when the owner of a P-51 elected to fly his airplane without the benefit of dual beforehand. After reading the pilot's manual he slipped the surly bonds sideways and going hard to the left, right over the flight line that was full of new Boeing airplanes. It finally got aimed better as he went over Lake Washington . I never heard about the landing but I guess that he accomplished it safely enough to stay out of the obituaries in the newspaper.
  4. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #29 Spasso, Nov 23, 2015
    Your question brings to mind a number of physical effects when applying high power to rotating propeller blades. (I borrowed this from the internet because I'm just not that smart to explain it on my own.)
    1) Propeller torque effect
    Torque effect is the influence of engine torque on aircraft movement and control. It is generally exhibited as a left turning tendency in piston single engine propeller driven aircraft.
    According to Newton's law, "for every action there is an equal and opposite reaction," such that the propeller, if turning clockwise (when viewed from the cockpit), imparts a tendency for the aircraft to rotate counterclockwise. Since most single engine aircraft have propellers rotating clockwise, they rotate to the left, pushing the left wing down.
    Typically, the pilot is expected to counter this force through the control inputs. To counter the aircraft roll left, the pilot applies right aileron.
    It is important to understand that torque is a movement about the roll axis. Aileron controls roll. Prop torque is not countered by moving the rudder or by setting rudder trim. It is countered by moving or trimming the aileron.
    This correction induces adverse yaw, which is corrected by moving or trimming the rudder (right rudder).
    On aircraft with contrarotating propellers (propellers that rotate in opposite directions) the torque from the two propellers cancel each other out, so that no compensation is needed.
    2) P-Factor
    P-factor is the term for asymmetric propeller loading, that causes the airplane to yaw to the left when at high angles of attack.
    Assuming a clockwise rotating propeller it is caused by the descending right side of the propeller (as seen from the rear) having a higher angle of attack relative to the oncoming air, and thus generating a higher air flow and thrust than the ascending blade on the left side, which at the other hand will generate less airflow and thrust. This will move the propellers aerodynamic centre to the right of the planes centreline, thus inducing an increasing yaw moment to the left with increasing angle of attack or increasing power. With increasing airspeed and decreasing angle of attack less right rudder will be required to maintain coordinated flight.
    This occurs only when the propeller is not meeting the oncoming airflow head-on, for example when an aircraft is moving down the runway at a nose-high attitude (in essence at high angle of attack), as is the case with tail-draggers. Aircraft with tricycle landing gear maintain a level attitude on the takeoff roll run, so there is little P-factor during takeoff roll until lift off.
    When having a negative angle of attack the yaw moment will instead be to the right and and left rudder will be required to maintain coordinated flight. However negative angles of attack is rarely encountered in normal flight. In all cases, though, the effect is weaker than prop wash.
    ** The P-factor helped the Blohm & Voss BV-141 observation airplane to fly in a straight line. In terms of thrust vs drag asymmetry, the countering of induced yaw was a more complicated matter. At low airspeed, it was calculated to be mostly alleviated because of a phenomenon known as P-factor, while at normal airspeed it proved to be easily controlled with trim. Yes it was a real and it flew..
    3) Gyroscopic Precession
    This is the tendency of a spinning object to precess or move about its axis when disturbed by a force. The engine and propeller act as a big gyroscope. However, gyroscopic precession is likely to be minimal in a typical aircraft.
    Gyroscopic precession is frequently confused with p-factor.
    *The above conditions probably contributed to what my Dad witnessed back in the late 40's at the end of the local USAAC airfield "One a day in Tampa Bay"
  5. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    #30 Bob Parks, Nov 23, 2015
    The B-26's that killed so many pilots when they had an engine failure on take off was mainly due to a coupling of asymmetrical power and lift. A great amount of lift was provided by the prop wash from the large diameter props and short wings on the Martin B-26. When an engine failed, the loss of lift on one side and the drag of the dead prop on the same side tended to make the airplane yaw and roll over. The only solution was to kill the good engine and try to maintain control as you descended. My late brother-in-law flew these airplanes in the Pacific Theater during the war and he said that hard as it was to handle at times, he would chose it over the B-25 to go into action because it was so tough. During the war my brother flew with him on a stateside trip from Ca. to Washington, D.C. Crossing Arizona they dropped to low level and flew down into and out of the Meteor Crater in a B-26. He said that was quite an experience from the bombardier's position.
  6. Gatorrari
    Gatorrari F1 World Champ
    16,543
    Georgia
    Jim Pernikoff
    This was a factor in a couple of well-known midair disintegrations of Lockheed Electra airliners in the 1960 time frame. Weakened outboard nacelle structure would allow the propeller/engine combinations to wobble in this fashion if the aircraft was excited by an event such as clear-air turbulence. When the frequency of the wobbling equaled the harmonic frequency of the wing, the entire wing would flap until it failed - typically less than 20 seconds. The phenomenon was known as whirl-mode flutter. It was more likely in turboprops because of the large spinning mass of the engine.
    Lockheed rotated all Electras through its Burbank plant and beefed up the wing and outboard nacelle structure at its own expense, and the problem never recurred, nor has it with the many Orions around the world designed with the same wing and engines.
  7. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Induction of terminal pucker factor.......;)
  8. ralfabco
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    I guess P-51 pilots will not be impressed with my Super Decathlon checkout (sad face).
  9. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    i mentioned this GP problem in my book when I worked with an engineer who determined what happened when the wings started coming off the Electras. She designed the flutter model and figured out what had to be done to cure the problem. The engines thrust line was rotated upward several degrees, the nacelle skins were thickened, engine mount bulkhead was strengthened, and wing skins were thickened. If one looks close at the contour of the upper nacelles you can detect a break in it where the forward part of the nacelle was rotated up. An interesting phenomenon.
  10. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    You shouldn't knock yourself about flying a Decathlon. You are doing the same things that you would do in flying a P-51, just not as big and noisy. You're flying a tail dragger, you're responsible, and it's mostly a matter of training, and the right amount of attitude and skill. I wish that I was flying a Decathlon!
  11. sparky p-51
    sparky p-51 Formula 3
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
    #36 sparky p-51, Nov 24, 2015
    A tail dragger is a tail dragger. My first td was a Citabria with a 150 hp Lyc. Seems like that little bugger was always wanting to follow the left turn lane. The 51 wants to do the same thing, just quicker, so its heads up all the way. Line up on runway.Take off is mash on the brakes. 30 in manifold pressure. Let the engine stabelize. One last check of fuel and oil pressure. Drop left hand down and check flaps up. Touch rudder and elivator trim for take off. Friction lock on t quad. Hyd pressure and t handle in. controls unlocked and free. Check that the canopy is locked. One last quick look around cockpit. Release brakes and slowly advance throttle to 40-45 in MP and keep it straight. Ease up on stick until tail wheel lifts about 1 ft then back pressure.Airplane accilarates quickly..hopefully...squeeze in more throttle up to 55 in MP and the howling little monster should be flying. Reach down with left hand and gear handle up and adjust trim for climb out. Should be going through 130 miles now. Keep nose down til 180 mph and climb out. Take off in a 51 is parallel to sex but without the nagging. Great little airplane. If I had as much money as Bob Parks and could have any fighter it would be the Mustang. Whew...
  12. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    If you had as much money as B.P. , you would be in deep due due...like living on Boeing retirement and SS. Thanks for the P-51 description. Sounds like I remember it but I had the feeling that at the initial start before any speed was reached, there was little or no directional control other than brakes and full right rudder. Then as the tail got up, it felt better . From what I saw during the war a careless mistake produced disaster mighty quick and final. Mentioned before, early in the war some of the pilots went over seas in P-40's with a total of 240 260 hours to face an enemy that sometimes had thousands of hours in combat.The P-40's based at Sarasota in 1942-43 were crashing sometimes at one or two a day when a new bunch of cadets arrived from advanced training. My buddy and I went out to the airbase almost every weekend to see the show and many times you just had to be anywhere nearby to witness a crash. I remember in 1944 that the newspaper had a big headline that there were 11 crashes in the state in one day and they thought that there was sabotage afoot. It was almost routine.
  13. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    my preference for tail draggers is a performance take off ( if memory serves ), fewer transitions to adjust for...
  14. Tcar
    Tcar F1 Rookie
    What is a "performance take-off"?
    I can guess, but...
    A description?
  15. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    In my old airplane it meant that there was only one bounce before it got airborne.
  16. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    performance take off is like short filed take off or non paved runway take off,
    I always had more than adequate power, couldn't afford the laundry bills if the plane needed a bounce or two :=)
  17. donv
    donv Two Time F1 World Champ
    26,362
    Portland, Oregon
    Don
    I remember hearing about a P-51 owner who would start his takeoffs pointed 45 degrees off the runway heading... I don't know how many takeoffs he actually did, to tell the truth. Maybe one...
  18. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    i would bet that one did not cheat more than several times in something like a P-51
