a fire started | FerrariChat
a fire started
Discussion in 'Technical Q&A' started by cars30, Jul 21, 2006.
  1. cars30
    cars30 Rookie
    Aug 13, 2005
    18
    i was in new hampshire last weekend with my 89 testarossa.all was fine untill the way home .i suddenly lost power,and stalled,a few minutes later she started up i was somewhat relieved ,it happened again this time i feathered the gas as not to stall,no lights on engine and oil temp fine but i saw smoke there was a large flame shooting out my rear grill ,i managed to put out the fire ,remarkably there was literaly no fire damage .i am being told could be bad converters any help would be appreciated thanks
  2. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    One possible scenario is as follows. I'm not sure if it can apply to the TR, or a fuel injected car, but it does to the older carb V8 engines.
    For whatever reason, you lose ignition on one single bank. Power goes down next to nothing. You are dumping unignited fuel from one bank through the exhaust, and importantly, the catalytic converters. The catalytic converters are SO hot that they'll actually ignite the unburned fuel. Your "Slow Down" lights will come on as a result of the cat's temperature exceeding some amount.
    The fire starts at and around the cat and goes from there. You're lucky you didn't burn the whole car down!
    You need to flatbed to a mechanic and diagnose the ignition system on each bank. Also, a failed alternator or ignition coil or other electrical system component could be a contributing factor.
  3. cars30
    cars30 Rookie
    Aug 13, 2005
    18
    thanks mike i did notice one coil wire melted. dont no if it was prior or caused by fire
  4. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    A malfunctioning coil would definitely cause the scenario above - no coil, no spark.
  5. KatMan
    KatMan Formula Junior
    498
    Silicon Valley
    Stan K
    I have heard that cat fires are not uncommon on the TR.
  6. JAYF
    JAYF Formula 3
    May 13, 2006
    1,140
    Westchester, NY
    Jay
    Check the wires by the distributor cap on both banks and see if any came loose- I had this happen on my TR 3k miles after a shop replaced the wires. I came to find out that 1 of the wires wa snot screwed in properly, worked itself loose and arched causing a small fire and melt down of the distributor cap. Its very rare that cats heat up and cause a fire on the TR.
