A fun physics question | FerrariChat
Discussion in 'Other Off Topic Forum' started by 2000YELLOW360, Dec 18, 2005.
Astronaut
  1. Does not get any juice coming up the straw
  2. Enjoys a sugar high from the juice
  3. Spills coke all over the rocket
  4. Watches the coke can explode
  5. None of the above (added by mod for his own personal amusement)
Multiple votes are allowed.
Results are only viewable after voting.
  1. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    An astronaut takes a bottle of juice into space. Once in space (no gravity, no air pressure) the astronaut opens up the bottle , careful not to spill the juice. Next, the astronaut inserts a drinking straw into the bottle and makes sure the straw goes halfway down into the juice. This astronaut has a special nose breathing suit so his mouth is free. He sucks on the straw. What happens?
    Bonus question, if you answered that nothing happens, what would you need to do to make sure the juice goes up the straw?
  2. loki
    loki Guest
    Jul 25, 2005
    227
    Since you said "no air pressure," then the can of Coke will spray out. If you don't believe that, just open a can of Coke here where the air pressure is 14.7psi and see what happens
  3. shiznut123
    shiznut123 Karting
    Nov 15, 2003
    93
    Is his mouth exposed to space?
  4. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    I changed the question when I realized this...it is now juice! I left the last two choices worded with coke on purpose...to make it easy to eliminate them!
  5. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    Mouth is exposed to space. Astronaut has other end of straw in his mouth. One end in juice in bottle, the other in his mouth.
  6. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    If he is in space without air pressure, he couldn't drink anything because he's dead.
    But, if he happens to survive his time in space with only a nose breathing apparatus, and tries to suck the juice out of a bottle with his mouth, via a straw, nothing happens. He would have to blow the air meant for his nose, into the bottle to displace the area previously occupied by the juice, to release the juice into the straw and into his mouth.
  7. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    #7 MarkPDX, Dec 18, 2005
    I'm not sure exactly how it would all go down due to my limited knowledge of anatomy (suffocation or maybe something more spectacular?) but the astronaut would die in rather short order because any air in his (or her) lungs would rush out into the vacuum of space. I have had the pleasure of a simulated rapid decompression in a chamber.... 8k feet to 25k feet in 1 second will take your breath away :)
    Additionally the juice/soda/water whatever would be rapidly boiling away........
  8. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,425
    SFPD
    Dirty Harry
    Since "spills 'coke' all over the rocket" is a poll option, this indicates he's inside the craft, and it's feedin' time.
    If such is the case, and he's enjoying some anti-gravity, he absolutely must drink the entire contents of the juice container through a straw, otherwise - it's anywhere and everywhere, and as such, the preceding option is the one I've chosen.
  9. rammsteinmatt
    rammsteinmatt Formula Junior
    Jul 26, 2005
    371
    Glendora, CA
    Matthew Shinavar
    goes into space with only a nose piece to breathe - air rushes out of lungs, whole body freezes/melts (its real cold/hot out there), gets bombarded by huge radiation doses (depending where he is and is facing
    has open container of juice - juice boils/freezes depending what the sun conditions are like
    suppose juice didnt freeze, there would be no relative gravity to keep it down (assuming we are in orbit)
    assume we are in an aritficial vacuum, so we could complete this mission without dying. straw into cup, suck.....sucking the lack of air in the straw will not create a low pressure and therefore pull fluid up the straw :)
    isn't space fun?
  10. shiggins
    shiggins Formula 3
    Nov 20, 2004
    1,280
    I think he has bigger problems than getting the juice if his mouth is exposed to the vacuum of space.
  11. Kram
    Kram Formula Junior
    Jul 3, 2004
    867
    Park bench, Canada
    Mark
    Ignoring the odd space suit construction, if the astronaut is in open space then the instant he takes the cap off the bottle the liquid will boil (that is evaporate before reaching the liquid’s surface) away and become a gas mixed with ice crystals. What he will be in fact holding is a small rocket motor with a liquid propellant. Forget the straw, he won’t be able to get anything near the bottle top! For every action there is a equal and opposite reaction, thus the spewing contents of the bottle will probably cause him to spin about uncontrollably, or, if he is looking directly down at the bottle top, the drink will shoot out of his hand and zoom away.
    It will be a hell of a mess either way.
