A intermittent squeal over my left shouder? | FerrariChat
Discussion in '348/355' started by gcthree, Aug 4, 2008.
  1. gcthree
    gcthree Formula Junior
    Jul 18, 2008
    323
    Williamsburg, Va.
    Only happens once in a while, but I'll get a not-too-faint squeal (with the window dropped) from over my left shoulder. Doesn't do it all the time, and generally after it's been run for a bit. Fan on the left side coolant radiator?.....or?
    Bob
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    ..............could be the LH fan, they do have a habit of shearing the fan shaft drive pin.... :(
  3. gcthree
    Jul 18, 2008
    323
    Williamsburg, Va.
    Thanks! Makes sense given the noise. Best checked from below the car? Do you need to pull the fan down to repair should it be the culprit?
  4. jm348
    jm348 F1 Rookie Owner Silver Subscribed
    Mar 21, 2007
    3,017
    Redondo Beach, CA
    Jeff M
    Does your wife or G/F sit on your left? :D
  5. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    It is a fairly involved job, though can be done with hand tools :). One must jack the car, remove the left rear wheel and remove forward section of wheel well liner. All fan related bolts/screws are accessible from there.
    There are a few sellers of the spal fan but you will have to swap the factory connector to the new fan. So make sure polarity is in the 'pull orientation' then solder those wires ;).
    Reassemble in reverse............. :cool:.
    Sources of the replacement 16" Spal Fan:
    http://www.ricambiamerica.com/product_info.php?products_id=206349
    http://www.the-fan-man.com/shop/size-pull-part-2049-p-219.html?osCsid=c5b9027f5137ba744d1d40e666124cd1
    http://www.streetrodstuff.com/Products/256/
    http://www.off-road.com/diesel/News:+All/SPALs-New-High-Output-Fan-Cools-Heavy-Duty-Vehicle/ArticleStandard/Article/detail/531653?contextCategoryId=45938
  6. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,055
  7. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    If it is free shipping then it is a great price :) ................. otherwise the second link I posted is only $117 .............. ;)
  8. gcthree
    Jul 18, 2008
    323
    Williamsburg, Va.
    Finally got around to pulling the wheel and removing the wheel well liner to access the fan. Sure enough, the pin was sheared. Don't laugh, but as a temporary fix until the new Spal fan arrives from the link F355Spider provided, I put some Mighty Putty (yes, the stuff that Billy Mays hawks on TV) on the fan shaft. Damned if it didn't work perfectly?! However, having such a ghetto fix on the 355 would just drive me nuts, but as an interim fix it was perfect. I can always keep the fan as a spare, 'cause if it's happened once.....
    I also took the opportunity to spray some Simple Green on the suspension bits, chassis, etc and get it all nice and pretty.
    Cheers,
    Bo
  9. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,228
    Mount Isa, Australia
    Pap
    Thanks for letting us know Bob. :):)
    Goth picked it like an itchy ring. ;);)
  10. gcthree
    Jul 18, 2008
    323
    Williamsburg, Va.
    You bet, Pap.
    BTW, the Mighty Putty stuff is all that it is advertised to be. Cut-off a piece, knead it together for 2 minutes, and it provides a near permanent fix. It sets-up in 60 minutes, too. I recommend you salt some away in a tool box for a bunch of reasons.
  11. 285ferrari
    285ferrari Two Time F1 World Champ Sponsor
    Sep 11, 2004
    20,974
    MD and NE
    Robbie
    HAHA!!! My GF got me a pack of that putty. I have used it a few times for little things around the house and it worked perfectly!!
  12. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Good to hear decent feedback on that stuff. I think I will try it out now. :)
  13. gcthree
    Jul 18, 2008
    323
    Williamsburg, Va.
    Here's the latest. Save your money: The SPAL fan from 'Street Rods by Michael' worked perfect! The fan and the blade housing is exactly the same as the OE Ferrari bit....except it's $125...not $300! And shipping was free- they had it to me within 3 days!
    You'll need to retrieve the mounting ears from the OE fan (pop right off), and then spice the wiring connector from the OE fan onto the new fan (different connector). Other than that, just bolt it in and then listen to the sound of the fan purring away over your left ear.
    How does Ferrari and Ferrari parts dealers get away with tripling the price on readily available parts? It's criminal....
  14. 285ferrari
    Sep 11, 2004
    20,974
    MD and NE
    Robbie
    Glad to hear it worked out Bob!! I will add that fan to my aftermarket(non-expensive) parts fixes for the Ferrari...
