A Little Charging Help Please | FerrariChat
Discussion in '360/430' started by cborgrx, Nov 13, 2011.
  1. cborgrx
    cborgrx Karting
    Aug 16, 2005
    81
    huntington, n.y
    chris borg
    My 430 would not start yesterday after a dormant period so I was not surprised. I hooked the factory Ferrari charger to the car and after an overnight of charging, the green light showing 100% was lit so I figured I was good to go....tried to start it and it sounded just about the same as before charging.....click, click, click and nothing. What am I missing? Thank you in advance...Chris :(
  2. Ducati
    Ducati Formula Junior
    Jan 23, 2004
    364
    So. Cal
    Joe
    In my experience your battery is probably gone. They do not survive well if left uncharged. I suggest you keep the battery charger on regularly after you get a new battery. I have had very good results with the Battery Tender Plus. They do not overcharge the battery. I am still on my original battery with a Challenge Stradale. Now going on 7 years.
    Having said that, out of the 10 Battery Tenders I own , 2 have gone bad and had to be replaced by the manufacturer. I also had the charger on the Scuderia go bad and Ferrari replaced with a larger one.
    Batteries can be challenging.
  3. wang
    wang Formula 3
    Feb 23, 2004
    1,998
    Brunei
    H. Wang
    Yep, sounds like your battery can't hold charge anymore. You can try to use a charger like Ctek (official Ferrari supplier) which has a recondition mode which will recondition the battery.
    See if that works. Good luck....
