Hey guys, I just got my car back a week ago from an annual service and today I noticed a small puddle of green stuff under the front driver side of the car. I know there are radiators above this spot with fans on them right and most radiator coolants are green? So, I think it should be coolant leak of some sort. Could this happen from an overfill of the coolant fluid or is there an actual crack and is seeping from that? Any1 had this same issue b4? Thanks! Image Unavailable, Please Login
Slight antifreeze leak, doesn't look like anything serious. Another forum member had a similar issue and it was just a loose nut connecting the radiator hose to the radiator itself If it was a blown hose or cracked radiator, the fluid would be leaking all over the place. Just take it back and have them go over it. If you want to check it yourself, you will have to remove the inner wheel liner and use a flashlight to look it over. Hopefully nothing too serious. Best of luck
