A lot of problem with my 355F1 | FerrariChat
Discussion in '348/355' started by Serch, May 8, 2015.
  1. Serch
    Serch Rookie
    Apr 23, 2015
    22
    Spain
    #1 Serch, May 8, 2015
    Hello.
    My 355 have a lot of problems.
    - The light of Airbag is ON (17).
    - The light of suspension is ON (19)
    - Some times, the car show "slow down" (16) but I change the gear and the message disappears
    - The system of AC dont work (neither hot nor cold)
    - The door of gas tank dont work well.
    Please, I need your help for repair the car.
    If you see well, I can open a different theme for everything ...
    I need to buy a reader OBD??
    Excuse my poor english, I'm spanish
  2. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    Air bag light is very common- lots of times if it reads bad resistance on one of the bags it will come on and stays on. You may be able to reset with a SD1/2 diagnastic tool and it may stay cleared.
    Suspension light is common- usually a bad actuator. Pull them all off the tops of the shocks, flip them over and see if the all turn when you turn the key on and off.
    The air conditioning hot and cold. You don't have the STOP button pushed do you?
    Slow down light only over heated catalytic converters or a defective part in that system. Lots of threads on this if you search.
    Gas lid popper being sticky is also super common issue. Try lubing it up with WD-40. If that don't work there is a good thread on tearing the whole thing down in the 355 DYI thread.
    Just take on one thing at a time and you'll get them solved. Just have fun with it and don't let all the little things feel like they are piling up on you.
  3. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    Look at the bright side ,you didnt mention any f1 problems.
    1994 ferrari 348 spider , third owner purchased may 2013 w/ 27804 miles
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    And you just jinxed him. He's only got 4 posts, there is still time.
  5. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    Sounds like someone who drove his car for a long time and ignored a lot of things. Wanna bet the last service was a decade ago.
  6. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    At least the previous owner didn't pull out all the bulbs on the dash! I had some of these issues. Take them one by one.
    SDL- most likely it is a thermocouple or one of the ECU's. there are three of each. One for each CAT and one on the bypass.
    Lots of good threads on each of these topics and lots of good people here to help.
    I have the KIWI OBD2 reader and the Dash Command App. You need a code reader.
  7. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    When I got my 355 someone had nicely trimmed up some black tape and put it over the air bag light. I drove it for at least two months before I even realized it was tape covering a light.
  8. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    For sure. All the problems I have had with my car have been easy fixes once I did some research. I just had a failed header and now that I have removed both I realized I over analyzed the repair. It's a car bro. Treat it like one.
  9. Serch
    Serch Rookie
    Apr 23, 2015
    22
    Spain
    #9 Serch, May 9, 2015
    Well.
    First. I need a lector OBD, but, Which model is right ?? SD-1 is only for Airbag or is OBD??
    Then, I will begin by the light of the airbag.
  10. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    The airbag light needs to be reset using an SD. I have had it done twice at no
    charge.
