355 - a place to rebuild power steering pump | Page 2 | FerrariChat
355 a place to rebuild power steering pump
Discussion in '348/355' started by bellwilliam, Sep 1, 2021.
  1. Carmellini
    Carmellini Formula 3
    Jul 16, 2019
    1,013
    I think you are right.
    Why is there a limiting valve? purpose?
  2. m.stojanovic
    m.stojanovic F1 Rookie
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    #27 m.stojanovic, Aug 15, 2025
    It is actually a flow restrictor, a metal block with a hole in it, considerably smaller than the ID of the hose. It limits the dynamic pressure to the steering rack, i.e. smoothens out pressure spikes onto the rack in the cases of sudden quick turns of the steering wheel. It also limits the free flow of the ATF when going straight which is especially required at higher pump rpm-s, to prevent, I guess, too much turbulence of the fluid in the reservoir. It is believed that the restrictor is also there to eliminate noise of the PS system.
    It looks something like this:
    The restrictor is usually inserted into the hose and crimped over just to prevent it from moving downstream. So, there should be no leaks there as there are no joints in the hose at the restrictor, unless, of course, it happens that the hose is damaged at the restrictor location.
    Carmellini likes this.
  3. Carmellini
    Jul 16, 2019
    1,013
    Can the restrictor be reused?
    Having a bit of a fight trying to remove the fitting for this hose at the firewall.
    At the moment, the hose is winning.
  4. m.stojanovic
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    Of course it can be reused provided it is carefully removed. Carefully cut the crimp and push the restrictor out of the hose (the shop will know what to do).
  5. Carmellini
    Jul 16, 2019
    1,013
    Finally, was able to crack the front firewall fitting by using a 17mm flare nut wrench on the pipe,
    22mm flare nut wrench on the fitting along with a pvc pipe for leverage.
    To anyone playing along, I strongly recommend using proper flare nut wrenches and NOT
    standard box wrenches. You will be a world of pain if you round the 17mm nut on the pipe
    to the steering box.
    I wish there was a way to test the hose off the car? It looks too nice....I was hoping to see a gash
    or imperfection to confirm it is bad.
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
  7. Carmellini
    Jul 16, 2019
    1,013
    Proceeding slowly but would like to figure this out and get back on the road. This shouldn't be this difficult.
    Visually, the high pressure supply hose looks new. I blocked one end and pressurized while submerging in
    a bucket of water and no air bubbles anywhere to be found. Is this a conclusive test? Perhaps I am not inducing
    enough pressure?
    Performed a similar test with the (new) reservoir and no bubbles. (I thought it might be defective or the bracket might
    have cracked it)
    The pump is my last frontier, but there was no dye anywhere near the pump and can someone explain how dye
    could be in the valley if the pump were leaking?
    Any suggestions on how to independently test the pump without removal? I could connect a barb and hose to the output site
    and pressurize the supply side, but without fluid how would I find a leak? Or if I was able to pressurize the pump
    how much pressure is enough and how much is too much?
  8. m.stojanovic
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    I suspect you didn't. The PS systems operate at around 1300 psi.
  9. Carmellini
    Jul 16, 2019
    1,013
    LOL...I was around 30 psi ,,,,,,ha ha
  10. Carmellini
    Jul 16, 2019
    1,013
    Was able to get hose properly tested and confirm it is leaking. I guess that's a start.....lol
    Many calls and original 167568 is long gone NLA. Was told this hose is prone to leaks.
    Local shops argued with me and said that was not a restrictor but evidence of a prior repair.
    Other shops unwilling to reuse my oem fittings.
    Need to find a place I can trust?
  11. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    That local shop is no good. Send it to Tri-Vally Hoses, in Livermore CA. They have done it for me before.
  12. Carmellini
    Jul 16, 2019
    1,013
    Mitchell: Just spoke to Joey from Tri Valley and will be sending my hose out tomorrow.
    Dumbfounded that the local shops are so inept. This should be a simple job. Thanks!
  13. Carmellini
    Jul 16, 2019
    1,013
    Getting a bit ahead of the story but wanted to thank @yelcab for recommending Tri Valley Hose!
    They leak tested my hose and found a pin hole leak that they believe was caused from inside the hose....very strange.....???
    Happy to have that confirmation.
    In addition to being competent, they were incredibly fair and reasonable. Total cost was just under $100. WOW!
    Now is the long wait for shipping.......the saga has been going on for weeks and I forgot how much I love driving this car.
  14. Carmellini
    Jul 16, 2019
    1,013
    Rebuilt hose installed and problem solved. Tri Valley Hose did a great job and thanks again to @yelcab
