A quick, cheap and permanent fix for broken 355 seat potentiometers | Page 2 | FerrariChat
Discussion in '348/355' started by AFASTA1, Apr 7, 2010.
  1. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
    I don't think it matters which position, as long as you set the seat pot to the correct resistance for the position.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    I LOVE I T !!!!!
    How in the heck did I miss this thread? Oh yeah 348's don't have power seats. What ever the case, AWESOME post!
  3. roadracer311
    May 6, 2009
    2,398
    San Francisco
    Paul
  4. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    #29 ernie, Sep 30, 2011
    With pics even.
    :D
  5. mpodgor
    mpodgor Formula Junior
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    Is this a common Failure on the 355? Should I brace myself for seat malfunction?
  6. tashier
    tashier Formula Junior
    Sep 8, 2008
    573
    Oregon
    Sean
    Ummm, Ya!
  7. tashier
    Sep 8, 2008
    573
    Oregon
    Sean
    Heh, I see that I posted on that thread long ago so I must have seen it once before. It's like a ghost from the past when I see stuff I posted that I don't remember. Great thread though man and I will definitely have it handy this weekend.
  8. roadracer311
    May 6, 2009
    2,398
    San Francisco
    Paul
    Good luck this weekend! Let us know how it goes!
  9. AFASTA1
    AFASTA1 Rookie
    Jun 4, 2008
    37
    Montclair NJ
    Jeff
    #34 AFASTA1, Sep 30, 2011
    I've come up with a few more "pearls of wisdom" since originally starting this thread. here goes:
    1. "Epoxy" is not as permanent as i thought. after a year or so, the grease in the seat pot denatured the epoxy to the point where something that was once rock hard was now like silly putty. that is to say, the seat pot failed again after a year. when i re-did the repair this time, i used hot glue, which afte researching it a bit, seems to be impervious to all kinds of petroleum based lubricants. so far so good after about 6 months.
    2. you don't need a multimeter to measure the resistance of the seat pot in various positions. it turns out to be even simpler than that. look at the attached photos to see the relative position of the very center slot of the seat pot. if you plan to re-install the seat in the full forward position, the center slot needs to point from 8 o'clock to 2 o'clock when you put it all back together. if you plan to re-install the seat in the full back position, the center slot needs to point fromm 10 o'clock to 4 o'clock. these positions correspond to the correct ohm readings i cited in my original post. just put mit back together as described and no need to get a multimeter or have the Ferrari tech put an SD computer on it.
    hope this helps. good luck.
  10. tashier
    Sep 8, 2008
    573
    Oregon
    Sean
    Thanks for the update. I didn't get around to messing with it this weekend. Painting the house and running an excavator all day Sunday. Hope to get on it next couple days.
  11. pfbz
    pfbz Rookie
    Sep 25, 2009
    19
    Yes, i realize this is a very old thread... and that there are a half dozen other similar threads. Helping a friend with his 355 Spider, sounds like the typical 'bad pot' problem. Honestly, this set them to 600 and do not reconnect them to the seat tracks method sounds a hell of a lot better than trying to glue broken shafts back together or source unobtainium replacement parts...
    Sure seems like having the driver ensure the seats are not all the way back before operating the top is totally reasonable and a far better solution than the overly complex and failure prone 'factory' setup with fragile position sensors and computers.
    Thoughts?
  12. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    763
    Vermont
    john truskowski
    If you fix the pots by installing the small roll-pin as suggested in posts here the system will function as designed, but I do agree that it is the most ridiculous power convertible top ever conceived by mankind.
  13. Qavion
    Qavion F1 World Champ
    14,601
    Ian Riddell
    Or simply buy a repair kit
    https://www.ebay.ca/itm/143665671697
  14. Red_SLR
    Red_SLR Karting
    Jul 22, 2019
    115
    Simon
    Just thought I would update this thread with what I did recently after my second problem in 3 years with the seat pots. I have no idea if its the right procedure but at this moment my roof is now working again!
    Symptoms were the passenger seat was stuck all the way forward. Roof inop. Roof would work on the emergency switch but pax seat stuck all the way forward still.
    I turned off power to the car and unplugged the multi plug but left the seat power plugged in.
    Repowered the car.
    I then removed the rear seat bolts and turned the ignition on and moved the seat back using the switch on the console.
    Removed the front bolts.
    Turned off power again and unplugged the power cable to the seat.
    Removed the seat.
    I then removed the drive unit / drive shaft and removed the potentiometer.
    Upon opening I found that the potentiometer was very stiff and the plastic ball joint would just spin on its ball and not actually turn the potentiometer.
    I cleaned the unit and applied silicone grease. Ran it back and forth a few times between its max and min hard stops.
    I then cleaned the seat mountings with an M8 die ( think it was M8) as there was a lot of crud in there.
    Refitted the seat and connected seat power only.
    Turned car power back on and moved the seat all the way forward and back to get the seat bolts in.
    I then motored the seat all the way back to as far back as it normally goes.
    Turned off power to the car and re-connected the multi plug.
    Then turned power back on and sent the seat all the way forward.
    Then sent the seat all the way back.
    I did this a couple of times just to be sure and cycled the ignition a few times too.
    Then just to be sure I killed power to the car again and left it for half an hour then tried again and it was still ok.
    Then I tried the roof and it was operational again.
    The seats move as they should and return to the correct position after operation of the roof.
    I have no idea if the ECU learned the new values or if its still using the old ones, but either way its working and as best as I can tell the potentiometer really cant go much further than full aft and forward anyway so I think you cant really mess it up. HTH.
    Qavion likes this.
  15. Qavion
    14,601
    Ian Riddell
    I think the Roof ECU is using the old values. Moving the seat to the endstops manually has probably reset the pots to the right starting positions, thanks to the regreasing. The old values would have needed to be set with a Ferrari SD1 tool.
    My car is in for a major at the moment. I’ll ask my tech next time I see him how he uses the SD1 tool to do the relearn.
  16. AFASTA1
    AFASTA1 Rookie
    Jun 4, 2008
    37
    Montclair NJ
    Jeff
    Had to have my top hydraulic system rebuilt (including pump, rams, solenoid block and hoses) after 27 years. The 30 amp fuse kept melting without blowing so I figured it was time. TopHydraulics.com did a great job with the rebuild. Took the seats out to make that job easier so I decided to inspect my seat pot repair from 2009- still looked fine. I put the reconditioned pump system back in and all works like new.
