A QV engine in a 308 GT4? | FerrariChat
Discussion in 'Technical Q&A' started by kevfla, Jun 7, 2005.
  1. kevfla
    kevfla Formula 3
    Nov 20, 2003
    2,086
    gone 4 good
    Congrats to Michael (The Carreaper) on his very recent acquisition of a Series 1 car. His purchase made me wonder if later 308 engines such as the QV or even 328 engines can be fitted into a GT4. That would be a helluva track car!
    KevFla
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,249
    E ' ' '/ F
    Splenda Daddy
    I've seen a modded QV in a 308GTBi, so I know that's possible. Can't see why a QV motor wouldn't work in an earlier car. The only thing is that all the electronic gizmos would have to be moved too. That's the one major advantage of the GT4, it was always a carb'd car :)
  3. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    There is GT4 in Australia with a QV with carbs. Goes very well apparently. Some of the Aussie guys may have pics....
    Dave
  4. 208 GT4
    208 GT4 Formula 3
    Dec 27, 2003
    1,769
    Brighton (UK)
    Dan
    This is something I've been considering, as someone in the UK had a QV engine and gearbox for sale from a Mondial recently. I know I'd at least need a higher pressure fuel system and a new exhaust. But I didn't have any idea if the engine mounting points and clutch etc would fit?
  5. davidgt4
    davidgt4 Karting
    May 28, 2003
    227
    Surrey
    David W.
    You know you want to:)
  6. 208 GT4
    208 GT4 Formula 3
    Dec 27, 2003
    1,769
    Brighton (UK)
    Dan
    Problem is, it could easily end up costing more than just buying a 308 GT4!
  7. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    There's an excellent chance that the QV block will mate up with your GT4's bell housing & transmission. You'll need the QV bell housing spacer for the sensors, & qv flywheel to trigger them unless you go carb'd & custom ignition.
    I recently spoke with someone who'd dropped a 328 block onto a QV trans. Only mods were to the vibration damper & damper bolt to accommodate the slightly longer 328 crank!
    The 328 engine mounts are definitely different from the QV mounts, so the match-up avoided that problem.
  8. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Why would you want to do this??? Lose the carbs??? No way!
  9. gva
    gva Rookie
    Jul 16, 2004
    37
    Melbourne Australia
    Graeme Vincent
    Ther is a 308GT4 fitted with a QV engine injected and carb in Australia. Conversion worth more than the cars.
  10. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,035
    Summerfield, NC
    Tom Jones
    There is one here in NC but I haven't see it in a while. Had a custom made flywheel with a Quartermaster clutch (which sucked). Not really nice but did function. I've heard of a Dino that had a 308 engine that I think Norwood built.
  11. thecarreaper
    thecarreaper F1 World Champ
    18,094
    Savannah
    thanks for all your help ! :) if you ever in Savannah, please look me up.
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Installing a QV engine doesn't necessairily require installing the CIS system & ECUs. There's at least one carb'd 328 written up in fchat.
  13. thecarreaper
    18,094
    Savannah
    hey, thats a GREAT IDEA!!!!!!!! i would LOVE TO GET A 4V car and yank all the FI off of it and carb it :) ( evil Reaper grin)
    i wonder if the older carb car intakes will work, or if something custom would have to be made???
    thoughts?
    we need Atlantaman to chime in , as he seems to take engines out of his modded QV on a regular basis. the 330V12 should be a blast to drive when its back in the QV! :cool: perhaps he can help with the GT4 swap details since he uses 328 4V engines.
  14. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Russ Turner (Snj5)'s 3.2 liter Mondial carb conversion threads from the old fchat should have pretty much all you ever wanted to know about converting a 328 (3.2 Liter) engine to Carbs. The 3.2L carb intake risers were made by Modena Engineering in AU.
    Luckily all the pix seem to have survived:
    1. Technical Q&A Archives: Archive through August 24, 2003: 3.2 Weber conversion; first pic and issues
    http://70.85.40.84/~ferrari/discus/messages/256120/300846.html
    2. Technical Q&A: Archive through September 11, 2003: 3.2 carbs and single distributor; part 2
    http://70.85.40.84/~ferrari/discus/messages/112/307711.html
    3.Technical Q&A: Archive through October 01, 2003: 3.2 w/ carbs - new pics - part 3
    http://70.85.40.84/~ferrari/discus/messages/112/310267.html
    4. Technical Q&A: Archive through October 20, 2003: 3.2 with carbs - IT'S ALIVE - part 4 - new pics
    http://70.85.40.84/~ferrari/discus/messages/112/317785.html
    5. Technical Q&A: Archive through October 20, 2003: 3.2 carbs / MILLERMON distributor - part 5 w/ pics
    http://70.85.40.84/~ferrari/discus/messages/112/323574.html
    6. Technical Q&A: Driving a 3.2 with carburetors compared to fuel injection
    http://70.85.40.84/~ferrari/discus/messages/112/337753.html
  15. Sloan83qv
    Sloan83qv F1 Rookie
    2,537
    with BIG Dave M.
    Little Dave M.
    #15 Sloan83qv, Jun 9, 2005
  16. thecarreaper
    18,094
    Savannah
    THANKS !!!!! YOU ROCK!!! duh? dont know why i didnt remember these threads!
  17. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Paul,
    That engine is absolutely awesome. Can't wait to see the dyno data on that...and the bonnet to go over those trumpets!
    My little fusebox is proud to be in that car!
    Birdman
  18. Sloan83qv
    Sloan83qv F1 Rookie
    2,537
    with BIG Dave M.
    Little Dave M.
    Still fabricating items but getting close to 1st run out of the shops parking lot. Now that the brakes have an auxilary source of vacuum stopping is now possible.
  19. Organiser
    Organiser Formula Junior
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    A friend of mine has fitted a fuel injected 3.2 to his GT4, the car was used in the UK classic race series and he still drives it on the road.
    I will ask him for some pictures and post them later.
    Regards,
    Phil.
  20. Dr Tommy Cosgrove
    36,538
    Birmingham, AL
    Tommy
    What would the advantage be with the QV motor ? A 308 carbed motor from that era would be more powerful. The only way to gain an advantage is to build one like Sloan, with carbs.
  21. 1975gt4don
    1975gt4don Formula Junior
    Nov 5, 2003
    665
    Peoples Rep of CA
    Smog Exempt
    I got a woody looking at those pics! BEAUTIFUL!
