a simple maths question! | FerrariChat
Discussion in 'Other Off Topic Forum' started by Z0RR0, Dec 17, 2005.
  1. Z0RR0
    Z0RR0 F1 Rookie
    Apr 11, 2004
    3,470
    Montreal, Canada
    Julien
    #1 Z0RR0, Dec 17, 2005
    Since everyone seems to be having fun with stupid questions ... here's one for y'all. I don't have the answer. And it's annoying.
    What gives?
  2. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    That's pretty cool. I believe that the squares are being added together in a different way than they are being divided up, and that results in the addiitional square. But I don't really know.
  3. PeterS
    PeterS Five Time F1 World Champ
    52,238
    Goodyear, AZ
    PeterS
    Piece of cake, as it's an optical illusion, powered by the outlines on the sections they move. First, they make two slices and rearrange things a bit. The blue slice creates two triangles, and the red slice creates two trapezoids. Rearrange as desired, and without any outlines to cover things up, this is what you get:
    See that white gap? It's a parallelogram with an area of 1, which is why 64 seemingly equals 65. Warning: geometry and trig follow. Start off noting that the two blue triangles are identical, as are the two red trapezoids. For the blue triangle: looking at the smallest angle, you know the adjacent side is 8, and the opposite side is 3.
    32 + 82 = x2, so the hypotenuse is 8.544 tan-1(3/8) = 20.556° For the red trapezoid: look at the slice that happened. Basically, it took a triangle (green) out of a square to make the red trapezoid.
    On that triangular piece, looking at the smallest angle, you know the adjacent side is 5, and the opposite side is 2. 22 + 52 = y2, so the hypotenuse is 5.385 tan-1(2/5) = 21.80°
    Given that it's the slice that was removed from the 5 x 5 square to result in the red trapezoid, you know the acute angle of the trapezoid and the length of the slanty side. 90° - 21.80° = 68.20°
    Length of slanty side = removed section hypotenuse = 5.385
    Now you know the acute angle of the parallelogram in the middle. 90° - 68.2° - 20.556° = 1.244°. So now you know everything you need to find the area of the parallelogram: opposite sides blue are 8.544, opposite sides red are 5.385, and the acute angles are 1.244°.
    Area of a parallelogram is base times height, so you need to draw a right triangle inside. The following diagram is totally skewed for clarity, but the values are accurate.
    See how easy this is! :)
  4. shiznut123
    shiznut123 Karting
    Nov 15, 2003
    93
    Its an illusion. When u do it precisely, there is a thin space between the diagonal line going left to right.
  5. PeterS
    52,238
    Goodyear, AZ
    PeterS
    That's what I said, but explained the details of the math.
  6. shiznut123
    shiznut123 Karting
    Nov 15, 2003
    93
    ooops, i didn't see ur post =)
  7. PeterS
    52,238
    Goodyear, AZ
    PeterS
    Of course you can't do it. All lawyers can add up is hours! :) :) :) :) :)
  8. AzN-TriNi
    AzN-TriNi Formula Junior
    Oct 24, 2004
    373
    it's not an illusion, I think it has something to do with the slopes of the lines.. not sure how to explain, maybe someone else could
  9. PeterS
    52,238
    Goodyear, AZ
    PeterS
    Did you not read post #3?
  10. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    a very neat visual teaser.
    thanks for the explanations, Peter.
  11. UroTrash
    Jan 20, 2004
    40,519
    Purgatory
    Clifford Gunboat
    check my profile for a similar one.
  12. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    Yours is interesting as well. I see that the hypotenuse in the second arrangement describes an area which would be equal to the 1 box square left blank.
  13. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,962
    MD and NE
    Robbie
    WTF???--Peter you lost me after piece of cake--I started to get hungry and lost all concentration..
