A Solution For A Rainy and Wet Trac | FerrariChat
Discussion in 'F1' started by miketuason, Jul 18, 2018.
  1. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,807
    Cerritos, CA.
  2. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    The link didn't work for me...
  3. william
    william Two Time F1 World Champ
    27,641
    Same here ...
  4. miketuason
    Feb 24, 2006
    15,807
    Cerritos, CA.
    Oops sorry! Try this:
    william likes this.
  5. jcurry
    24,070
    In the past
    Jim
    It is very rough. Probably not the best for tire wear.
    Being used on a lot of commercial building lots here in WA. Requires considerable work underneath to provide path for water.
  6. william
    27,641
    Interesting.
    Maybe not possible on old circuits because of the necessary ground preparation, but that should be tried on new tracks.
    miketuason likes this.
  7. william
    27,641
    Interesting.
  8. BMWairhead
    BMWairhead Formula 3
    Sep 11, 2009
    1,062
    Portland, OR
    Ted
    Self draining tarmac has been used on F1 tracks before. I don't believe it drained as much as the video implies...
    I don't recall which track(s) it was... probably a Tilke-drone built in the last twenty years.
    Bas and miketuason like this.
  9. miketuason
    Feb 24, 2006
    15,807
    Cerritos, CA.
    Maybe this is the new design tarmac where it can drain more and faster, I just knew F1 can benefit from this.
  10. thirteendog
    thirteendog Formula 3
    Mar 6, 2008
    1,587
    Nashville, TN
    I wonder how well it’ll hold up to the grip and torque of the cars.
  11. Solid State
    Solid State F1 World Champ
    10,575
    Maximus Decimus Meridius
    Wherever that water winds up it has to be managed below the surface just like on top. You don't want that gathering somewhere under a normal road or against a building subfloor wall.
  12. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,426
    FL
    Yes it requires a lot of prep under it. It's nothing new, but here's a video that shows how it's done:
    Track surfaces are different than what that would offer...
  13. WPOZZZ
    WPOZZZ F1 Veteran
    Aug 22, 2012
    6,508
    Honolulu, HI
  14. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,721
    So, video 2 shows that one has to dig up the first 4-5 FEET of the road bed in order to install the based on which the asphalt is applied.
    The road would also need high capacity drains at rather regular intervals.
    I don't think any track could afford such a surface.
  15. Drive550PFB
    Drive550PFB Two Time F1 World Champ
    Porous Asphalt?
    How about transparent aluminium?
  16. BMW.SauberF1Team
    Dec 4, 2004
    14,426
    FL
