I have a question I'm hoping someone with a 360 Manual Gearbox car could help me with. I am looking for the measurements of the gate. I plan on CNC machining one for a piece of art I'm working on, and would like it to be precise. Ideally, if someone has the time to measure the following, I would be greatly appreciative of the gesture: Length and width of the gate top to bottom length and width of "slots", and length and width between approximate size of screw holes in each corner, and the length of the Cavallino The height (from a side angle) looks like it's approximately 1/2" "tall" since it rises in the middle (correct?) Anyway, I know that's a strange request, but it would really help me out. Thank you, Cheers! Ken Image Unavailable, Please Login
Width 78mm lenght 100mm. Slot width 11mm slot lenght 58 mm slot total width 52 mm reverse lenght 40 mm. Cavilino is 15mm high by 10mm wide. Screw heads are 10 mm wide. The shifter is rounded making the max center heigth 11 mm but the top and bottoms 8 mm thick. Good luck!
@Bigilo Thank you! When I finish this piece, I'll post it and see what the encompassing group thinks. Again, much appreciated! Cheers, Ken
