A Stupid electrical question | FerrariChat
Discussion in '206/246' started by MRONY, Jun 6, 2007.
  1. MRONY
    MRONY Formula Junior
    Mar 17, 2007
    707
    New York City
    Mike O.
    Whenever I use athe lights in my 74, the ammeter skews almost to pin on the left. I know that's reflecting the current change, but I've never seen such a dramatic meter change in any other car. Is that normal, or a sign of an issue? Despite the fact that my grandfather was one of NYC's senior engineers, I know zippo about electric engineering, particularly DC...
  2. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Mike - Is this issue one you notice when engine is idling? It might be normal at idle, but not when above 1500 RPM.
    The ampere meter reads 40-amps max-0-min. Fifty watt headlights at 12 volts will draw 4.2 amps (rounding) each. Multiply by 2. Add tail lights, (5 watts each x 2, or total of 1 amp). Add dash lights (approximately 2 amps), add front parking lights (approximately 2 amps total), add capacitive ignition, add coil current, add fans (if on - 8 amps), and you get approximately 20 amps total. These are, as we say, engineering approximations.
    I would expect a 20-amp, or half-scale deflection of your amp meter. The meters are quite inaccurate, and a full scale deflection would not be out of the question. The important observation is whether the needle centers with slight increase of RPM.
    If, indeed, the meter is accurate, then one must entertain a low resistance path to ground (not a short circuit, which would blow a fuse, but low resistance to ground). If one of the light conductors is touching ground through a rusted surface, this could create such a finding. However, another way of adding up the numbers is simply to follow the circuit diagram and see which fuses are uses to light the lights. Add up the capacity of all of these fuses and see if they approach 40 amps. Better yet, remove one fuse at a time and see which one results in the largest drop. If it is NOT the headlights, then there is, perhaps, a low resistance path to ground.
    Hope this helps.
    Jim S.
  3. dm_n_stuff
    Dec 10, 2003
    43,745
    26.806311,-81.755805
    Dave M.
    Jim.
    Could also be his charging system, right?
    If he's running wit a 35 year old alternator that's seen better days, he could easily be discharging the system even at 1500 rpms or more. And they have a separate regulator too?
    The charging system really isn't made to run everything in the car at once. And, you forgot to include A/C in the calculation, which would drag him even farther into the red.
    Additionally, inefficient motors (cooling fans that need service) could add significantly to the load.
    When I replaced my cooling fans with new, and replaced my alternator with a modern one from an Alfa, all my charge/discharge problems went away. MY car actually will run at 0 at idle, even with lights on. OF course the new alternator makes significant additional amps.
    Also, remember the amp gauge is looped into a fairly main circuit, is it not? Mine just got rebuilt and had just about burned through one of the terminals. That could also cause a big problem it not attended to.
    Ahh, the joy of old cars.
    Disclaimer. I'm not an EE, nor do I profess to be an expert on this stuff. I'm just relaying personal observations. And your mileage may vary. But I did sleep in a Holiday Inn last night..
    DM
  4. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Dave - your observations are right on. No question that alternator health and fan health make a great contribution to good/bad things.
    However, the fundemental question is the number of amps flowing from the battery to the lights. As you correctly observe, the amp meter is in series with the main battery conduit. Hence, all current to and from the battery flows through it.
    Mike's initial question could have been stated, "...when the engine is off, and I turn on my lights, the needle drops to 40 amps discharge..." The status of the alternator does not come into play with his concern (if I understand correctly).
    No doubt that if the radiator fans, air condition, windshield wipers, lights, etc., etc., are all energized that the 40 amp discharge is appropriate. Mike did not provide information as to what other loads (devices) were active during this observation. This information would help.
    For those interested, the amp meter simply measures the balance of current being supplied by the battery to the car, and by the alternator contributing to the battery charge. Hence, if the car requires 10 amps to function, and the alternator is generating 10 amps, then the amp meter will read zero. This assumes a full charge to the battery. When the load requirements exceed alternator output, then there is negative flow (from the battery to the car), which lowers battery voltage. The regulator senses this, increase field current to the alternator, which then generates more current to supply the car and recharge the battery.
    To understand alternator output requirements, simply turn the car off and turn on all loads. This includes air conditioning, lights, wipers, and radiator fans (by shorting the switch on the radiator), radio, etc. You will see the amp meter discharge, perhaps, 30 amps. Now add charging current of 10 amps, and one arrives at a minimum of 40 amps output by the alternator. Stated differently, when driving down the road on a raining night, with all fans going, wipers on, lights on, A/C on, etc., and the amp meter reads plus 5 amps charging, the alternator must supply the car's requirement (e.g., 40 amps) plus the charging current to the battery (arbitrarily 10 amps), or 50 amps.
    Jim S.
  5. dm_n_stuff
    Dec 10, 2003
    43,745
    Dave M.
    This is interesting!
    electrical detective work. Haven't done that since I tried to figure out why the three way hall switch didn't work right, only to discover that there was a wire color change from the box at the top of the stair to the box at the bottom of the stairs.
    So, if I understand this, we need to know if this drain is with the car running or not. If the car is running, probably an alternator PLUS wiring issue, if car is off, might not be a problem at all.
    MIKE, is the reading with the car at idle? With the car off, or at running speed?
    Dave
  6. MRONY
    Mar 17, 2007
    707
    New York City
    Mike O.
    The amp meter deflects almost 100% in idle when I turn on JUST the lights. The fans were not running as far as I could tell, and no other accessories were on. I also am reasonably certain the meter deflected almost as much driving with the lights on as well. I will check it tomorrow. I noticed it the first time I put them on, which was at speed on a back road at dusk. (Even with the headlamps on, I wouldn't call the Dino the world's greatest night driving car, but it has the daytime title sewed up.
    It sounds to me like it could be an alternator issue, and that running electric accessories is draining the battery as I drive rather than charging it. Of course, I plug in the battery tender whenever I park the car for more than a few hours now, because I'm paranoid.
    I knew I would learn a tremendous amount from the answers to this post. I'm going to read up...
  7. dm_n_stuff
    Dec 10, 2003
    43,745
    Dave M.
    Sounds like you're discharging, even when you're running with good RPMS.
    For sure, not the best situation, but, exactly the same situation I was in.
    Does you car have a cutoff switch under the front hood? If so, bypass it. That may help. Mine had a bad ground as was systematically draining my battery.
    The rest needs some tech help. Measure the output of your alternator. IF it sucks, time to rebuild/replace. Again, I went with a more modern 80 amp (might have been 65) alternator, which caused some issues on its own, but we fixed pretty quickly, and now, even at idle I don't discharge the battery.
    Happy hunting!!!
    DAve
  8. MRONY
    Mar 17, 2007
    707
    New York City
    Mike O.
    #8 MRONY, Jun 7, 2007
    Added to the list for the first trip to the shop. I've put about 450 miles on it since I got it, right after a pretty thorough servicing by Juan Villareal out in SF-area. I'm figuring another 250 miles and I'll take it to one of two recommended shops in the general area and go through the list (except for the starter, which I'm gonna do with Champ...)
    The car is driving just beautifully. I've decided not to bother changing the radio for a long while. The engine is the best music you could ever listen to!
    I'm thinking a few of the hoses Juan left in might be candidates for replacement...
  9. tx246
    tx246 F1 Veteran
    6,663
    Texas
    Shawn
    the car has so many original items, only replace what you have to.
    every time i drive my dino at night, i leave the high-beams on. it doesn't help the electrical drawl, but the "older" high beams are much less intense than the current low beams (zenon, etc....)
    i have yet to have someone flash at me......
    during the day or night, i typically see a needle go negative at idle. with high rpm's it doesn't seem to be a problem.
    that being said, i live in houston. the a/c on dino's is comical at best. it won't due crap here, so i rarely run them. clearly, this helps on my power drag.
  10. MRONY
    Mar 17, 2007
    707
    New York City
    Mike O.
    The system got a fresh charge before shipping out, and it actually works really well... blows cold and strong and makes just enough of a difference even on a 90 degree humid day (like we had last week). If it had one or two dash vents, you might think you were in a Ford pickup.
    I also notice very little loss of power from the unit, unlike the factory one on my '66 Mustang, which barely works and really sucks the juice out of the engine.
  11. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    I'm not sure about US versions, but on our "Euro", a three-position stalk controls parking lights only (up) low-beams (middle) and high-beams (down). It's all to easy to go to parking lights when you want to dip the high beams, which can be pretty exciting! I think I'll try the high beams all the time thing, though I rarely drive it after dark.
