A weird problem with my alarm today. | FerrariChat
Discussion in '360/430' started by pingi3, Dec 12, 2009.
  1. pingi3
    pingi3 Formula 3
    1,551
    Atlanta
    Quack
    Wanted to see if any of you guys had this problem before. My 360 Spider sat for a few weeks. I drove it last night for a few miles. I drove her again this morning. It was pretty cold. I parked her after driving about 30 minutes. I left the doors unlocked. I go back to leave and open the door and push the remote fob and then the cars alarm goes off. But the kicker is the car starts. I turn the ignition off and try to reset by pushing and locking the doors. I open and restart the car but still the alarm is beeping.
    I called FOA and they were at a lost. They said I might have to wait till the battery dies that is separate from the cars battery. I waited like 20 minutes and still going off. I said screw it and drove her to FOA.
    Left the car their.
    Any body want to take a stab at the cause. Or has anyone here experienced the same problem before?
  2. RayJohns
    RayJohns F1 Veteran
    7,926
    West Coast
    Ray
    You can probably kill the alarm by turning off the master battery switch in the front compartment. I would start by resetting the ECU (by turning the power off as outlined above for about 5 minutes, then turning it back on). If the problem continues, it's probably because the battery in the alarm/siren module is leaking and may have started to destroy the printed circuit board.
    Ray
  3. photonut
    photonut F1 Rookie
    4,080
    Michigan
    Joel
    are you using the battery tender when the car is not driven?
  4. pingi3
    pingi3 Formula 3
    1,551
    Atlanta
    Quack
    No battery tender.
  5. pingi3
    pingi3 Formula 3
    1,551
    Atlanta
    Quack
    Did not try the reset with the main battery but that sounds lime a good place to start. Unfortunetly the car is up at FOA. Im pretty sure they went into the front compartment to undo the battery for the alarm. I hope it is not a leaking if the acids like you mentioned. I know wire issues suck.
    Thanks for the input.
  6. tazandjan
    39,174
    #6 tazandjan, Dec 12, 2009
  7. pingi3
    pingi3 Formula 3
    1,551
    Atlanta
    Quack
    The siren did sound pretty puny. This was the first time I heard he alarm and if I was stealing this car, I would not even bother with the alarm.
