A2D-BRKCD bluetooth receiver for F430 with Becker BE 6112 questions | FerrariChat
Discussion in 'Technical Q&A' started by Atlantic, Feb 14, 2023.
  1. Atlantic
    Atlantic Formula Junior
    Oct 19, 2015
    363
    Porto, Portugal/New York, USA
    Rob
  2. clex2
    clex2 Karting
    Aug 30, 2009
    103
    I did. It’s perfect. No noise suppression needed. Dual control of CD changer and BT. Highly recommended.
  3. raemin
    raemin Formula 3
    Jan 16, 2007
    2,388
    Lyon (FR)
    R. Emin
    the noise suppression devices are usually crappy and deplete the battery, as they keep on charging their built-in condenser. A healthy battery paired with a reasonably sized ferrite ring is a much safer bet. If you need a condenser, it's probably because the condensers inside your stereo are shot. So better to "recap" the head-unit in this case.
  4. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    719
    I did this on a 360 and it worked great but somehow I think the unit was resetting more often with the adapter installed. Not sure if it's a wiring issue or if the caps in the Becker unit are slowly dying and/or have become loose.
  5. DanNE
    Jun 7, 2013
    719
    *did NOT* need a noise suppression circuit.
