AAV Spec's do they exist? | FerrariChat
Discussion in 'Technical Q&A' started by waymar, Jun 9, 2009.
  1. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Does anyone have knowledge on the spec's for AAV (Aux Air Valves) 1982 GTSi or others....
    Would be interesting to know what the factory specs were for many p/n's to aid in trouble shooting and replacement choice.
    Mine is:
    280 140 129
    Have seen in the market:
    280 140 124
    280 140 125
  2. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    I just assume that Bosch thought they had bettered the design a good number of times. Other cars with the system have multiple numbers of different AAV's, without a specification for serial numbers or markets.
    There may be a difference for the cat and non-cat cars, but I think the differences are marginal at best.
  3. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Has anyone replaced an AAV 280 140 129 -? (1982 308 GTSi) What replacement p/n is recommended?
  4. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    Wayne, why are you replacing the AAV?..or was it just missing. I think you have a 2v 308, & if I'm correct I have the PN's from my 2v. I will need to check but can you tell us whats going on w/the AAV?
  5. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    The AAV does not open all the way it only opens about 1/4 - I tried to loosen the hex nut and push the valve back and snug the hex nut. But no change. It closes in the oven but jumps right back to 1/4 open a min or two out of the oven. Thinking I've messed up the setting now.
    Until part warm the engine will not hi-idle unless I disconnect the vac advance/retard line from the Digiplex then it warms up fine and I re-connect it when part warm. I've just sent my WUR to Larry for rebuild and we feel there may be a vac leak in the AAV or? I will also set my plate height and t-plate when the WUR is back on.
