About the AUTOMATIC TRANSMISSION Oil spill | FerrariChat
Discussion in 'Technical Q&A' started by ekinfans, Aug 30, 2014.
  1. ekinfans
    ekinfans Rookie
    Aug 5, 2014
    27
    china
    samuel
    #1 ekinfans, Aug 30, 2014
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Isn't the car still under warranty?
    I've heard that the DCT gearboxes are only sold as a complete assembly.
  3. ekinfans
    ekinfans Rookie
    Aug 5, 2014
    27
    china
    samuel
    ⊙﹏⊙ Only sold as a complete?
  4. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Perhaps that is true for the innards of the boxes, it sure does not mean that a simple shaft seal is not available.
    Even if not available from Ferrari, I am sure a reputable shop can remove the seal, take measurements and specifications and obtain a proper replacement for it. It would be pretty outrageous if a seal problem would command a total gearbox replacement.
  5. ChuckStyl5
    ChuckStyl5 Karting
    Mar 28, 2004
    180
    The Armpit
    the seals get replaced as well as the flanges -- but you should be under warranty
  6. ekinfans
    ekinfans Rookie
    Aug 5, 2014
    27
    china
    samuel
    I think so.
    But nobody knows the number for seal.
  7. ekinfans
    ekinfans Rookie
    Aug 5, 2014
    27
    china
    samuel
    But I can't find the seals for sold, the car no warranty.
  8. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,948
    The Cold North
    Tom
    You will have to pull the axle and the flange. On the seal there should be stamped a size usually 3 numbers separated by either a hiphan or an "x".
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It's a nearly new car. The ones sold here come with a seven year warranty. What's your story?
    If it's only a seal it should be an easy fix but the DCT gearboxes have had some failures. If it's anything more you will probably need a dealer.
  10. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    919
    Georgia
    Mark Gronsbell
    FWIW in the US the warranty is 3 yrs not 7. The 7 yr is routine maintenance e.g. oil changes etc not repair of other issues. The difference is huge.
  11. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    ^ this. Check carefully that the flange does not have excessive play (especially laterally).
  12. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Seems unusual for a one year old car to have leaks. The seal could be just the symptom rather than the real problem.
  13. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    Seems even more unusual that a one year old car doesn't have warranty..
  14. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    552
    Tempe
    Jon
    Unfortunately the dealer is not able to work on the transmission and each getrag trans will be shipped back to the company to be repaired. Just with through this procedure for a 2010 califronia where the wiring harness inside short circuited due to a clamp failing and allowing the gears to chew through the wires. Cost was over $20,000
  15. Doctor Mark
    Dec 15, 2005
    919
    Georgia
    Mark Gronsbell
    Thomas at Ferrari of Atlanta has had training at Ferrari on the DCT gearbox and they be serviced/repaired. Suggest you contact them- 678-802-5000.
  16. tazandjan
    39,164
  17. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Maybe you can point out where the internal parts are pictured. I only see mounting stuff.
  18. Rifledriver
    37,089
    It is in the Ferrari double secret eyes only parts book. The dealer could show you but he'd have to kill you afterwards.
    Or that output shaft could be removed and taken apart and the seal taken down to Bearing Engineering and matched up for $3.49
  19. Rifledriver
    37,089
    Tom is a good mechanic but go to a far corner of the country for a minor easily repaired oil leak?
  20. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    LMAO! The seal is an easy fix for some of us.
    Still no explanation of why a nearly new car isn't under warranty.
  21. tazandjan
    39,164
    Stolen?
    Tim- Beats me where it is in the parts catalog. I did not see it either, but that is the best info any of us mortals have.
  22. ekinfans
    ekinfans Rookie
    Aug 5, 2014
    27
    china
    samuel
    Sorry for late reply, and thanks for your answer.
    The car buy from Macau, but always drive in China. So if warranty, need back to Macau, will be trouble.
  23. ekinfans
    ekinfans Rookie
    Aug 5, 2014
    27
    china
    samuel
    Stolen?? OoO~~
    Haha~~
    It is said this car is too new, so the seal can not be order now…
  24. ekinfans
    ekinfans Rookie
    Aug 5, 2014
    27
    china
    samuel
    Yes
    But if inspections and rebuild need new seal,so I want get the seal first.
  25. ekinfans
    ekinfans Rookie
    Aug 5, 2014
    27
    china
    samuel
    Thank you very much.
