ABS Code 33 | FerrariChat
ABS Code 33
Discussion in 'Technical Q&A' started by ninot, Apr 17, 2008.
  1. ninot
    ninot Karting
    Feb 7, 2004
    225
    Sunny Staffordshire
    Nino
    Hi folks,
    I have a problem with the ABS on Mondial 3.2 - Car was fine until i dropped the engine, put everything back and car ran fine but the ABS is showing a code 33 -
    Have searched for previous threads but no one answered.
    Any thoughts
    Cheers
    Nino
  2. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    The listing for this code per the 348 manual is: 31-34: Lack of signal due to wire breakage or short circuit or internal ECU failure (31=left front, 32=right front, 33=right rear, 34=left rear)
    I believe the 348 uses the same ATE Teves ABS system. Good Luck!
  3. Mat@Premier-Motorcars.com
    Apr 16, 2008
    14
    Planet Earth
    Mathew J. Reid
    Your memory jives with what I found....
    Code Number Diagnosis
    11 open circuit in solenoid relay circuit
    12 short circuit in solenoid relay circuit
    13 open circuit in pump motor relay circuit
    14 short circuit in pump motor relay circuit
    21 open or short circuit in 3 position solenoid of front right wheel
    22 open or short circuit in 3 position solenoid of front left wheel
    23 open or short circuit in 3 position solenoid of rear wheels
    31 front right wheel speed sensor signal malfunction
    32 front left wheel speed sensor signal malfunction
    33 rear right wheel speed sensor signal malfunction
    34 rear left wheel speed sensor signal malfunction
    35 open circuit in front left or rear right wheel speed sensor
    36 open circuit in front right or rear left wheel speed sensor
    41 abnormal battery voltage ( < 9.5 or > 17 )
    51 pump motor of actuator locked or open circuit in pump motor circuit in actuator
    ALWAYS ON computer malfunction
  4. ninot
    ninot Karting
    Feb 7, 2004
    225
    Sunny Staffordshire
    Nino
    Thank you fellow F chatters as always - will check all connections
    Nino
