ABS ECU - I see 2 different part numbers | FerrariChat
Discussion in '348/355' started by FlyingHaggisRacing, Jan 27, 2015.
  1. FlyingHaggisRacing
    FlyingHaggisRacing Formula 3
    Jul 2, 2013
    1,377
    ABS ECU
    I see two different part numbers for this unit, but no other info on how to differentiate their application to model year.
    #131325
    #148838
    Anyone know the difference ?
  2. Bertil
    Bertil Karting Owner
    Sep 8, 2012
    199
    Stockholm Sweden
    Bertil Palmblad
    I Think the 131325 is for 328, Mondial, and 148838 is for 348 (Teves ABS)
    Maybe some one of the "pros" can chime in,,,
    Bertil
  3. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    If you need an abs ecu for a 348 its the same as a very common ford. 1985 lincoln if i remember.Dont pay the ferrari tax.
  4. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    I have a 1990 348ts and also had a problem with the ABS light failing to extinguish as it normally did after start up. After checking out the entire system and being unable to find fault with any components I assumed the "brain box" could be the problem. As a previous post mentioned the same component was used on late eighties Ford. Purchased one from a wrecker on E-Bay for $25.00 and works fine! JGW
  5. FlyingHaggisRacing
    Jul 2, 2013
    1,377
    LOL
    $25(ford) vs $325(ferrari).
    hmmm, that's a hard decision to make.
    What does the ford label show ... any pictures/part numbers ?
  6. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
  7. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    I think you better check again its alot more than $325 from ferrari over 1k when i checked
  8. GTO Joe
    GTO Joe Formula 3 Silver Subscribed
    Feb 15, 2013
    1,002
    Charlotte, NC
    Joseph Troutwine
    I have one of the EBay specials and it does look just like the original and has the same numbers from the supplier. It came out of a '87 Lincoln Mark IV. It is packed away so I can't get a quick picture.
  9. John Glen
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    Never mind you had better just buy one from Ferrari. Don't listen to anyone here....
  10. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,544
    Jeff
    Source: Workshop Manual Section G: Brakes, Teves ABS MKII brake system
    So it looks like they are interchangeable but the later 148838 has better software
