ABS ECU | FerrariChat
ABS ECU
Discussion in 'Technical Q&A' started by delaney, Apr 29, 2005.
  1. delaney
    delaney Formula Junior
    Nov 8, 2003
    721
    Montgomery TX
    PETER DELANEY
    Does anyone know of a company who will repair an ABS ECU computer from a '96 355 Spider?
    Regards,
    Pete
  2. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    If I recall correctly the ABS system is supplied by ATE. Have you tried contacting them direct? I do not know if ATE supplied the electronics. Curious because my 348 spider ABS system is indicating a fault somewhere.
  3. AR!
    AR! Formula Junior
    Apr 8, 2004
    981
    Berlin, Germany
    AFAIK Teves doesn´t exist anymore .. .. they have been bought by Conti Tech.
    ATE Teves units have been used for a variety of cars .. Alfa, VW, Ford .. ... I wonder, whether one could use a replacement from another car .. .. I suppose the software on the boards is different but otherwise the differences must be small ..
  4. delaney
    Nov 8, 2003
    721
    Montgomery TX
    PETER DELANEY
    I did the fuse trick and counted the flashes ..... 2...1.
    This code translates to 'Valve or connecting wire failure'
    Solution .. check valve resistances and continuity.
    Could anyone enlighten me on what this means?
    Best regards,
    Pete
  5. AR!
    AR! Formula Junior
    Apr 8, 2004
    981
    Berlin, Germany
    You need a manual that tells you which pins you must use to check the resistances and the proper values. I got one manual from Ford which I used to check the valve resistances in my t Cab .. .. but it´s in German.
