ABS Error-Help please | FerrariChat
Discussion in '348/355' started by peterkarvelas, Jun 29, 2010.
  1. peterkarvelas
    peterkarvelas Karting
    Jun 2, 2006
    78
    RSA-Johannesburg
    I have a 1995 355 with the teves abs system.
    I recently changed rotors to 355mm and calipers with s/s brake lines at the front.
    This entailed me needing to do a brake system bleed which was duly done and the complete system was flushed and bled.
    On taking the car out to road test I got the ABS warning light coming on and staying on as soon as the car reached a speed of 40km/h (25mph).
    I did a test sequence using the empty fuse holder and counting the ABS warning light on off sequences and it recorded errors from LF sensor RR sensor RF sensor as well as delivery valve failure.
    As the system was operative immediately prior to me doing the brake swap and bleeding I knew that the error codes I was receiving were "wrong".
    I unpluged all the sensors and cleaned the connections as well as the plugs on the ABS pump- brake fluid reservoir.
    The ABS light will now stay switched of up to a speed of 40km/h then come on and stay on untill roughly 80kh/m at which time if I manualy overide the ABS off and then on the ABS light will remain off as long as the speed is over 60km/h.
    I am now getting a 2.1 error code =Valve or connecting wire defective which is most strange as neither is the case as the system operates at a speed of over 60km/h.
    I would be gratefull for any input you may have.
