430 - ABS issue - need help please | FerrariChat
430 ABS issue - need help please
Discussion in '360/430' started by F430Bill, Dec 5, 2024.
  1. F430Bill
    F430Bill Karting
    Apr 21, 2021
    61
    South Florida
    Bill
    I have a 2005 F430 spyder that has a bad ABS module and I have tried sending it out for repair twice with no luck. Ferrari does NOT make the part anymore and I have been dealing with this issue for about one year.
    Does anyone have any suggestions on how to fix this issue or get a replacement part from Ferrari?
  2. Racer_X
    Racer_X Karting
    Oct 20, 2017
    108
    MI
    Tom
  3. imahorse
    imahorse F1 Rookie
    4,355
    WI
    Dustin
    Depends on what the issue with the module is. There are multiple parts in it. Oftentimes it's the pump, but that's not always the case.
  4. F430Bill
    F430Bill Karting
    Apr 21, 2021
    61
    South Florida
    Bill
    They don't have any and said none of their suppliers have them either. I am sorta screwed here and seeking help.
  5. imahorse
    imahorse F1 Rookie
    4,355
    WI
    Dustin
    Do you know what the issue is with the module?
    If you don't know I can't really help. If you just want to replace the whole unit reach out to the exotic dismantlers like Exotic Auto Recycling and Ferr pparts. If you replace it, I might be interested in your old one.
  6. vrsurgeon
    vrsurgeon F1 World Champ
    16,540
    Charleston, SC
    Curt
    This right here. Get a used unit, plop it in, and send the old to Dustin.
    imahorse likes this.
  7. F430Bill
    F430Bill Karting
    Apr 21, 2021
    61
    South Florida
    Bill
    Neither of them have the ABS module.
    Does anyone else have any suggestions
    Does anyone know how to contact Ferrari direct as I asked my local dealer ONE YEAR ago to contact Ferrari and so far have not had any response.
  8. vrsurgeon
    16,540
    Charleston, SC
    Curt
    Eurospares doesn't either? Veyr hard to believe...
  9. imahorse
    imahorse F1 Rookie
    4,355
    WI
    Dustin
    Pretty sure you can't get them new anymore. Same with 360. Do you know what is wrong with it? There are some abs unit failures I can fix.
  10. ItsAboutThatTime
    Apr 7, 2024
    101
    Arvada, CO
    Shane
    Hey Dustin, with your experience in repairing some items related to ABS, is there anything that can be done to ensure a long life of these modules? What are some of the codes/items you can repair and what can't be repaired? Is it a fairly common issue on the 430's?
    I don't have any issues currently, just trying to gain some insight as to if I can prolong anything on my end and if not, what can be repaired. Thanks buddy!
  11. imahorse
    imahorse F1 Rookie
    4,355
    WI
    Dustin
    I can repair units with failed motors which I believe is the most common failure point. The motors can fail when the cars are stored in high humidity areas with little circulation. Lack of use can also cause issues.
    LorenzoR and Qavion like this.
  12. ItsAboutThatTime
    Apr 7, 2024
    101
    Arvada, CO
    Shane
    Awesome, thanks for the info
