ABS module needed for F430 | FerrariChat
Discussion in '360/430' started by F430Bill, Nov 20, 2023.
  1. F430Bill
    F430Bill Karting
    Apr 21, 2021
    61
    South Florida
    Bill
    I have a 2005 F430 Spyder that needs an ABS module and looking for some recommendation or leads to obtaining a new part or possibly rebuilding my original one.
    Thanks.
  2. LorenzoR
    LorenzoR F1 Rookie
    Bill, if its the mechanic part of the abs your having issues with, you can probably fix that
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,968
    Isle of man- uk
    there is info on here in regards to this, try a search. From what i remember it is a common Bosch part but the setting up for a 430 is NLA. You might be worth trying the customer service at the factory a try to see what they say
  4. F430Bill
    F430Bill Karting
    Apr 21, 2021
    61
    South Florida
    Bill
    The issues is that we are still not sure what is going wrong with the car as the dashboard lights up and we think it is the ABS module, so not sure if it is mechanical or electrical, etc
  5. F430Bill
    F430Bill Karting
    Apr 21, 2021
    61
    South Florida
    Bill
    any other advice???
  6. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,783
    This diagnosis sounds a little on the woolly side! What codes are stored? Don't spend money before there's at least some certainty.
  7. vrsurgeon
    vrsurgeon F1 World Champ
    16,549
    Charleston, SC
    Curt
    Has the car been scanned with an SD3? when my ABS light was on it was determined to be a bad pump, specifically the motor. While I bought another ABS module, I just replaced the motor with a $30 spare unit from an audi. Taking the old unit apart it was obviously corrosion on the pump.
