ABS Mondial T | FerrariChat
ABS Mondial T
Discussion in 'Mondial' started by Jon22, Jan 24, 2005.
  1. Jon22
    Jon22 Karting
    Sep 4, 2004
    110
    Uk
    Jon
    Stiill having trouble fault finding the ABS, the light is permenantly on,I have tried the fault diagnosis in the book, but i still get the light on all the time, just the 1 light ( abs light) the brake warning light is fine. I cannot get anything from the fault codes as detailed in the manual. no flashes the light never goes out.
    As my light is always on, where do i look next, i know the Pressure pump is running as i hear it.
    Is it possiblke to test the ecu, it would be silly to replace it if there is no fault. Is there any where in the uk i could send it for testing?
    Any ideas welcomed.
  2. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    My 328 does the the same thing. I had a thread on the old board, but that is still being recovered after the server failure.
    The only thing that changed was once I overfilled the resevoir, and the light went out for almost a year. Doesn't make it go out anymore.
    I have stopped worrying about it, since the brakes work fine. The dealer has checked everything, and finds no faults or problems. He said the next step would be the ECU (you don't want to know the price), but no promises. Can always take the bulb out.
  3. maserati424
    maserati424 Rookie
    Apr 11, 2004
    29
    Berlin, Germany
    frank gablenz
    If you turn ignition on you must feel a click in the pedal after a few seconds thats the selftest routine ,and the sign for enough pressure in the system.
    You can test the wheellsensors with an Ohmmeter.
    Must be about 600-700 ohm.
