AC blower motor won't shut off~~HELP!! | FerrariChat
Discussion in '360/430' started by gperson, Dec 11, 2009.
  1. gperson
    gperson Karting
    Jan 2, 2008
    58
    Greensboro NC
    Griffin
    Greetings!
    I have a 03 360 spider. Sometimes the blower will not shut off. This problem is intermittent. After removing the key and closing the doors, blower sometimes remains on. After pushing all of the bottons on the dash....my only remedy is to cut battery power off under the hood. After awhile the circuit seems to reset and all is well till next time. I have replaced the AC ECM...thought it was fixed, but NOT. Back to square one.
    Thanks for your help!!
  2. mred
    mred Formula Junior
    Nov 2, 2003
    476
    Atlanta, GA
    Ed B.
    The opposite happened to mine - the AC wouldn't turn on. There is a blower motor restrictor that broke. Dealer didn't have much trouble fixing it.
  3. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    evidently a relay somewhere is acting up... power should be cut with key out.. unless a relay sticks in the closed position... my guess.
  4. gperson
    gperson Karting
    Jan 2, 2008
    58
    Greensboro NC
    Griffin
    Thanks for your post mred and charmer3.
    Hopefully someone out there has experienced the same problem. It is not just on AC it does it on heat as well. Same blower for both.
    Thanks again!!
  5. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    Try to find the relay for the blower- I would bet on it..
