AC Charging on a 328 question | FerrariChat
Discussion in '308/328' started by jcag, Jul 8, 2016.
  1. jcag
    jcag Rookie
    Dec 5, 2012
    9
    Santa Clara CA
    John Guinasso
    Why does the High pressure gauge vibrate at what appears to be the same frequency as the piston?
    Details:
    While charging the system, the High pressure gauge began, very slowly, to vibrate when the pressure reached ~125 psi.
    As I continued charging, both High/Low pressures continued to rise as expected, and so did the magnitude of the High side vibration (which made it difficult to identify true pressure).
    All components are new including hoses (except condenser and evaporator). Florence dye mixed with oil.
    Thoughts/suggestions?
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Rpm to low?
  3. jcag
    jcag Rookie
    Dec 5, 2012
    9
    Santa Clara CA
    John Guinasso
    RPM around 1800, fan blowing on condenser.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,968
    Isle of man- uk
    Assuming you have a valve on the pressure gauge, just throttle it in a bit until the gauge is steady, not too much or you will trap the reading and it will not read true
  5. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,876
    Mike 996
    Sounds like poor or defective gauge set. The gauges (should) have a restrictor that dampens the needle fluctuation. Sometimes they blow out on cheap gauges, where they are usually just a stamped piece of thin brass with a small hole.
  6. jcag
    jcag Rookie
    Dec 5, 2012
    9
    Santa Clara CA
    John Guinasso
    Hey Mike 32,
    I don't have a shutoff valve at the suction or discharge ports on the compressor, and I wish I did. I should have replaced them with some that were.
    I just took it for a ride and it seems to work fine.
    Thanks for your thoughts and suggestions.
  7. jcag
    jcag Rookie
    Dec 5, 2012
    9
    Santa Clara CA
    John Guinasso
    Hey Mike996,
    I like your suggestion. These gauges are very old but are already set up for R12. My other set is brand new but set up for R134a. I should have attempted to convert them so I could have used them instead.
    I'll do so this weekend and give feedback to the forum.
    Thank you
