AC compressor repair | Page 2 | FerrariChat
Discussion in '348/355' started by drbob101, May 17, 2020.
  1. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Looks like the only difference between the 348 and the F355 is the battery cutoff switch for the latter.
  2. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  3. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Always interested in how stuff works. Thought this was good.
    So what goes on these? The seals, the bearings the clutch?
    I would think after many hours beatings and over time seals. Seems a shame to trash it but I can’t find anyone to fix it.
    I’ll keep the old one in case someone wants parts from it.
  4. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
  5. m.stojanovic
    m.stojanovic F1 Rookie
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    The second link for the clutch assembly includes a 6-groove pulley whereas Ferrari's is a 5-groove pulley (and belt). According to some posts here, you can use a 6-groove pulley and leave one groove unused. Otherwise, you can search for a 5-groove pulley for the type of Sanden you have but may not be easy to find (could have been custom-made for Ferrari).
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    If you are ordering a replacement I think their was a company called bear or something in Florida that makes them
    I put a link in the parts sticky i believe.
  7. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Wade call polar bear as taz suggested. I’m getting my new unit from them and it has an aftermarket pulley on it that they said is identical to OEM. Maybe they’ll sell you just the pulley. Gretchen is the gal there and she’s been really helpful to me.
    Wade likes this.
  8. JLF
    JLF Formula 3
    Sep 8, 2009
    1,708
    #35 JLF, May 20, 2020
    Wade likes this.
  9. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    My bad. Drier is located under passenger (LHD) inspection cover. Upon closer inspection, what I thought was the drier under the windshield is the wiper motor.
    Also happens to be a black cylinder located right where the AC service ports are.
    Doh!
  10. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    emac and Wade like this.
  11. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  12. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Polar bear and no core
  13. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
  14. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,024
    PA
    Kevin
  15. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    That’s great thank you
    I got the Sanden version from them rather than the clone. I’ll post up the side by side of them in a bit.
  16. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,024
    PA
    Kevin
    I wonder when the actual Sanden became available. That was not an option last fall.
  17. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
  18. IvanRico
    IvanRico Karting
    198
    Westchester NY
    Ivan Rico
    So it looks like my AC compressor is leaking around the main seal - I was able to detect leaking refrigerant from around the pulley / shaft area of the compressor.
    Question - does anyone have part numbers for the o-rings for the compressor lines? Or for the drier lines? Or has anyone just used one of the generic kits with different sized o-rings available on Amazon like this?
    https://www.amazon.com/Beduan-AC376M-Compressor-Conditioning-Assortment/dp/B07R3RZN1S/
