AC Expansion Valve Sticky Goo | FerrariChat
Discussion in 'Technical Q&A' started by 328GTB, Jan 30, 2004.
  1. 328GTB
    328GTB Formula Junior
    305
    Texas, USA
    Carmine
    Anyone know what this sticky stuff is? What to replace it with?
  2. Kenny94945
    Kenny94945 Karting
    Nov 1, 2003
    203
    Marin Calif
    I have no definitive answer,
    however as a lead...it looks like a type of spray insulation foam that you could perhaps duplicate in a spray can product purchased from Home Depot or the like.
  3. BigTex
    79,212
    Houston, Texas
    Bubba
    It's a self fusing rubber compound.
    Check with an A/C supply company, like Johnstone.
    It comes in sheets.
  4. Dave328
    Dave328 Formula 3
    Nov 24, 2002
    2,133
    Katy
    Dave
    Yep, Speedy is right. It is a rubber/cork tape material. We get it by the roll at our shop. You will definitely need to replace it, otherwise condensation will flood the front boot! Try NAPA,Carquest,etc. AutoZone and Pep Boys may not carry it.
    BTW, are you changing the valve itself? Did you use factory or did you find a crossover? I need to change mine this summer.
    Dave
  5. BigTex
    79,212
    Houston, Texas
    Bubba
    I'm RIGHT!! Ha ha, a good day!
    Condensation is what they are trying to avoid, as noted.
    Actually, I purchased a new expansion valve by taking mine off and running to a local automotive A/C only supplier, they took it in back and matched it up!
  6. 1975gt4don
    1975gt4don Formula Junior
    Nov 5, 2003
    665
    Peoples Rep of CA
    Smog Exempt
    How much did they charge you for the expansion valve? TIA
  7. 328GTB
    305
    Texas, USA
    Carmine
    I was told one can get a similar expansion valve at O'Riely Auto Parts:
    Expansion valve
    Murray Climate Control
    PART#
    MRY 38683
    THP AC3801C
    UPC 9636138683
  8. Dave328
    Dave328 Formula 3
    Nov 24, 2002
    2,133
    Katy
    Dave
    Cool! Thanks!
    Dave
