AC expansion valve with capillary unit for a 308 | FerrariChat
Discussion in 'Technical Q&A' started by chairpilot, May 30, 2007.
  1. chairpilot
    chairpilot Formula 3
    Mar 3, 2007
    1,547
    LA, CA & Olympia, WA
    PlateClipGuys
    Does anyone know the part number for the expansion valve that controls the AC temp on my 1983 308 QV? The attached capillary tube runs through the firewall to the console temp control as a single sealed unit. A clue on a source and price would help too.
  2. 330gt
    330gt Formula 3
    Nov 12, 2004
    2,103
    Seattle, WA
    Kerry Chesbro
    I bought one (109819) for my '78 308 GTS from Rutlands a year or so ago. Under $75 at the time. Probably the same part for a QV.
    This is not the expansion valve, but the thermostatic switch. In the meantime, you can just jumper the switch. That leaves the A/C on high where it usually needs to be to get any cooling. Just turn the A/C fan switch to off when you don't want the A/C running.
  3. rustybits
    rustybits F1 Rookie Professional Ferrari Technician
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Yikes! Thats a dangerous game 330gt, jumping the wires on the switch will mean the a/c compressor is running all the time. It needs this switch to cut-out the compressor clutch when the pressures get high. Without this continuing switching action you could end up bursting a pipe or even wrecking the compressor!!
  4. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,512
    Cape Canaveral/Atlanta
    Walt P
    Rustybits, I think doing what 330gt is saying will let you turn the AC on and off as you want using the fan switch, nothing wrong with that as a stop gap measure.
  5. 330gt
    330gt Formula 3
    Nov 12, 2004
    2,103
    Seattle, WA
    Kerry Chesbro
    The switch in question senses temperature, not pressure. There are low and high pressure switches on the freon lines that function independently.
    When the temperature switch is fully clockwise (coldest setting), it is electrically on, no longer temperature sensitive, the same as being jumpered. Now, how many of you have ever had the temperature switch other than on the coldest setting? When you need the A/C in a 308, it is inadequate so the coldest setting is always needed.
    BTW, in most modern cars, the A/C compressor (if on) is running all of the time. The temperature control modulates the hot water flow through the heater core to control the air temperature.
  6. rustybits
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Ah, sorry guys, just read the post properly, and realised you weren't talking about jumping the trinary switch(doh!). Many modern compressors do indeed run all the time, but it's an entirely differrent set-up, as has been said. I will read posts properly in future........
