AC fan only blows on high and low speed, no intermediate settings work | FerrariChat
Discussion in 'Technical Q&A' started by ehagen, Aug 8, 2008.
  1. ehagen
    ehagen Karting
    Mar 20, 2008
    91
    Orlando
    Erik
    My AC only blows low speed or high speed. All intermediate speeds seem to default to the low fan speed. Has anyone else had this problem?
    This problem is on a 1999 360 modena euro spec.
    When fan speed is put in auto mode, and temp is anything except the low temp setting, the AC blows low speed only.
    When fan speed is put in auto mode, and temp is on 'low', the AC blows high speed only.
    When manually adjusting the fan speed, all settings except 'high' blow the AC at the low fan speed only.
    When manually adjusting fan speed to the high position, AC blows 'high'.
    I would like the regain these intermediate settings again. The high setting is too loud and unnecessary. And the Low setting isn't sufficient for Texas heat!
    Any help would be appreciated.
  2. swilliams
    swilliams Formula 3
    Jun 14, 2006
    1,407
    Bowling Green, KY
    Scott
    It should have a blower motor resistor, when they go bad low speeds wont work correctly. Call the dealer and ask for one. Also ask for the parts diagram so you can locate it and change it.
    Good luck,
    Scott
  3. f355spider
    f355spider F1 World Champ
    18,055
    #11 in this picture?
    http://www.ricambiamerica.com/parts_catalogs.php?M=FE&P=&V=diag&I=655
    Common failure in BMW's...been there, done that.
