AC Parts | FerrariChat
AC Parts
Discussion in '365 GT4 2+2/400/412' started by SouthJersey400i, Jun 21, 2010.
  1. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    I am preparing for the worse so just planning ahead at the moment. After 3 years my car's AC lost its R-12 Freon. It only needed 1 lb to bring back to correct pressure. However, in two months it lost its charge again. MY AC shop added the dye to detect the leak. I plan to have the car to him again next week. I will remove most interior parts that I can for him to find the dye. (While installing a new battery this weekend, I found some Freon connections behind the battery under the wiper motor which are reasonably accessible.)
    Ok, here is the question. If the condenser or evaporator are leaking, are there replacement parts available? Getting used AC parts is risky; they will need to be vacuum tested to be sure they are okay and I will go that route if necessary. Are new ones out there? Source? Fiat 132?
    I am hoping for an o-ring or hose but the condenser is the most vulnerable. The evaporator is the toughest to remove, but having removed the dash last winter I think I know the way.
    Ideas please.
    Ken
  2. tr0768
    tr0768 Formula Junior
    Oct 28, 2008
    736
    Lake Stevens Washington
    Howard Musolf
    Here is a couple of thoughts, 1st, I would ahve the shop add a small amount of r-12 and then draw a vacum on the system. If they can't pull a vacum, then add dye and charge the system. Once charged then watch for the dye with a black light, at all connections.
    In most cases you will find a "o" ring or seal that has failed, in some cases a compressor will have a valve sticking and allowing the freon to excape.
    Now assuming that the leak is just an "o" ring, these are inexpensive and easy to change. I would advise that a conversion to 134 refrigerant. This requires a new hi and low inlets redily avalible from NAPA. R-12 is damn near impossible to purchase and reguires a license just to install.
    Howard Musolf
    1981 308gtsi
    1982 400i Cabriolet
    Maserati Spider
  3. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    Howard
    My shop added the dye in April after 3 years without needing Freon. They did not find a leak in the area of the compressor. Many connections require a lot of dismantling of the interior. I have an appointment for them to do the dye check and I will dismantle as much as I can in advance of the appointment. (false panel in trunk, right side front carpet, louvers to interior) I lasted 2+ months so leak is significant and dye test should find it.
    This shop as a good supply of R-12, pricey but available.
    My posting is solely to determine if the leak is in the evaporator or condenser, what are my options? An o-ring would be a great result of the test, but I am just planning ahead for the worst.
    Ken
  4. racerboy9
    racerboy9 F1 Rookie
    2,647
    If you lost your R-12 charge I would go ahead and replace all your o-rings before you recharge.
  5. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    The dye leak detection will only find very large leaks. An good electronic leak detector (Yokogawa) will find the smallest of leaks. You have to find a shop that is willing to take the time to find a small leak. All the doors of the shop have to be closed, to keep air currents from blowing the freon around, and no one in the shop can be using any type of clorinated carburetor cleaner, as this will cause the detector to go crazy. I usually look for these small leaks after everyone else has gone home, so there are no doors being open/closed and no air currents in the shop. it is a patience game. Most of the detectors out there are crap, the Yokogawa is the only way to go.
    Brian Brown
    Patrick Ottis Co.
  6. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    Brian
    I believe I am working with a good shop specializing in both R-12 and R134a systems. I will know more on Wednesday. They have schedule my car for most of the day to work on. I have removed rugs and rear panel to give them the best access that I can without pulling the console. I found the connections behind the battery where the front/rear split is made.
    Ken
  7. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    My shop first did not know what to do because everything was working fine. They saw some bubbles in dryer so they pulled vacuum and recharged the correct weight of R-12 per my manual. No more bubbles. It was still cooling fine. After some poking around they got it to "fail". They found some loose connectors on one of the pressure switches on the dryer. By jumping out the switch the clutch re-engaged.
    So no significant leak!! No other mechanical issues in system. Problem may be the or simply bad wiring when the dryer was changed out from the duplex to the dual switch dryer. IN any case a reasonably easy fix.
    I will search the archives to find a source for the dryer. If anyone wants to reply with a supplier and part number I would be grateful. I know the subject is well covered in previous threads.
    Leaving for 4 days in the Finger Lakes in the morning. I have trim to put back together this evening and a quick was job and we will be off in a cool car. (sic)
    Ken
  8. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    I ran with the dryer switch connected normally and the connects fittng well. I ran cold for 3 mintues and then lost cooling. I put in a jumper around the dryer pressure switch and had cold air for the rest of my trip. It looks like the switch is faulty and I will be buying a new dryer/switch. This is good news: minor money and a known fix.
    See my more recnt post for new troubles on the road.
    Ken
  9. Ak Jim
    Ak Jim F1 Veteran
    9,619
    North Pole AK
    Just a work of caution on bypassing the pressure switch. To protect the A/C system they (the airconditioning elves) install pressure switch. The pressure switch has two functions. One is to protect against a pressure that is too low this keeps the system from running on empty, think how bad it would be to run the engine with no oil. The other is to protect from too high of pressure. To high of pressure could be from an over charged system or a system with a blockage in it. I would recommend putting a set of gagues on it prior to bypassing the switch. The switch could be bad or there could be a pressure problem; by hooking up gagues you can tell what the problem is.
  10. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    I questioned my AC shop a couple of times about it. I understand the concerns you mention. I hope to get new switch/dryer before enxt trip. I'm now running with AC off due to other issues on current road trip. Thanks for input.
    Ken
  11. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    Jim and others,
    We made it home in near 100 F heat. The AC finally gave out completely and the belts were smoking when it died. Jim, there is probably a good reason for those switches to be in the circuit! I figured I seized the compressor, but after letting cool down for a few minutes teh compressor spun okay.
    I have lots to debug in this system. Anyone know a source of York compressors (new or rebuilt) as this one has likely been overworked.
    Ken
  12. dstacy
    dstacy F1 World Champ
    11,998
    GMT -5 & GMT +1
    Dave
    I have a new in box hi/lo pressure switch if you're interested
  13. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    Dave
    I'll send you a PM to work out details.
    Ken
  14. dstacy
    11,998
    GMT -5 & GMT +1
    Dave
    Replied :D
