AC Pulley Saga | FerrariChat
AC Pulley Saga
Discussion in '308/328' started by robertgarven, Aug 20, 2010.
  1. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    Friends,
    I decided to replace the bearings on my original steel ac pulley. I got two new SKF Italian bearings and a new bolt. I forgot to put the small spacer between the bearings so I pressed them out and back in and felt a small rough spot when turning. I ordered another set and pressed them in and have the same problem. The old bolt was pressed in tight but the new one slides in with hand pressure. I took the snap ring out cleaned everything and played with it for a couple of hours and I can only think that I somehow messed up the pulley. The thing is massive so I am not sure how I could do this, but I do have a large press which is not perfectly square and possibly could have pressed one in a little crooked. When the bearings are pressed in and not touching via the spacer they roll smooth as butter. When they are pressed together there is a definite rough tick in one area. When pressed on the old bolt they are fine only when in the pulley I am having a problem. Since the bolt, inner races, spacer, washer and nut lock everything together I think I have a problem.
    Has anyone done this recently???
    Obviously these bearing very sturdy and probably overkill for this application but I do not want to put this back less than perfect or create some harmonic vibration so I am looking for a new pulley. Supposedly they are NLA and superseded by an aluminum one on the 348 but I am looking for an original one.
    I am approaching the 1 year mark now, on the home stretch!!
    Thanks for all your help
    Rob
    If any one has one laying around drop me a line!
  2. thecarreaper
    thecarreaper F1 World Champ
    18,137
    Savannah
    i have several OEM Ferrari a/c compressors and air pumps. i will look and reply later today with pics if i have one you can use. I think T Rutlands has prices for these listed on thier website, but i would gladly take less than whatever they want for one to help a fellow Fchatter out.
  3. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    When I did my Sanden conversion I eliminated that pulley assemble. The bracket I used allows you to adjust belt tension by moving the compressor. I would think you could get the bearings and bolt at some outsource shops.
  4. thecarreaper
    18,137
    Savannah
    Robert i found the compressor, let me know if you would like pics or any numbers off of it, to be sure you can use it.
    Michael
  5. robertgarven
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    Thanks to all I may have a line on a new or used one. I am talking about the tensioner pulley assembly, which is not part of the compressor. I have not messed that part up yet!!
  6. thecarreaper
    18,137
    Savannah
    oh, ok , sorry, i was confused. good luck.
  7. robertgarven
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    #7 robertgarven, Jul 18, 2011
    Friends,
    Just to let everyone know, I finally figured out what was wrong. After I torqued down the bolt it was perfect.... Lessons learned the hard way!!!!!
    BTW the way to torque this is because the bolt head is so thin, mount it in a vise with aluminum jaws and torque the nylock. I even tweaked the new bolt as you can see, by doing the opposite.......
    Thanks to all who helped!
    Rob
