AC question. | FerrariChat
AC question.
Discussion in 'Other Off Topic Forum' started by gougoul, May 4, 2006.
  1. gougoul
    gougoul Formula 3
    Nov 25, 2004
    1,305
    Geneva, Switzerland
    Hi,
    small and probably dumb question, is there a way to cool air in a room without having to extract the hot one ?
  2. AntonyR
    AntonyR F1 Veteran
    Apr 12, 2004
    5,426
    Los Angeles
    Antony
    extract the warm air? Can you not chill the existing air in there?
  3. teak360
    teak360 F1 World Champ
    Nov 3, 2003
    10,065
    Boulder, CO
    Scott
    Do you mean do you have to change the air in the room to cool it? If so, the answer is no. You do have to extract the heat though.
  4. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,504
    FL
    So you want something like a car where you can change it from recirculate to outside? I've never heard of that for homes, but I wouldn't be surprised if someone did it.
  5. John_G
    John_G Rookie
    Dec 27, 2004
    30
    Canton, TX.
    John Gislason
    Absolutely, there is no need at all to remove or add air to a room or vehicle to cool the air inside.
    You cannot, however, cool air without removing the heat from it. You do not cool air, you remove heat.
  6. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Exactly...this is the principle behihd (what people in Arizona call) "swamp coolers", aka evaporative coolers.
  7. rammsteinmatt
    rammsteinmatt Formula Junior
    Jul 26, 2005
    371
    Glendora, CA
    Matthew Shinavar
    basic thermodynamics law. surprisingly physics does apply to everyday life
  8. SRT Mike
    SRT Mike Two Time F1 World Champ
    Oct 31, 2003
    23,343
    Taxachusetts
    Raymond Luxury Yacht
    The only way to cool air without removing the heat to an outside place would be to introduce something cold into the room... i.e. if you put a bucket of ice in there it would cool the room down. The only other way would be an endothermic chemical reaction but both those solutions "run out".
