AC Water leak | FerrariChat
AC Water leak
Discussion in '456/550/575' started by jaticker, Jan 23, 2011.
  1. jaticker
    jaticker Formula Junior
    Oct 27, 2007
    251
    tampa
    John Annis
    On turns, water leaks out of the AC air supply grills on the tunnel. I guess a drain is clogged . Is this a dealer only problem ?
  2. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Water leaks inside the car? :):)
    Drain is blocked, anyone can unblock mate. Take it to local mechanic, a/c specialist or do it yourself. :D:D
    I dont know where the drain is on your car, but its underneath somewhere. Should see a little rubber hose hanging down somewhere. :D:D
  3. 308 GTB
    308 GTB F1 World Champ
    11,719
    New Jersey
    Barry Wolinsky
    #3 308 GTB, Jan 23, 2011
  4. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Bravo! :D:D
  5. 308 GTB
    11,719
    New Jersey
    Barry Wolinsky
  6. jaticker
    Oct 27, 2007
    251
    tampa
    John Annis
    I assume the belly pan will have to be removed.
  7. 308 GTB
    11,719
    New Jersey
    Barry Wolinsky
    #7 308 GTB, Jan 23, 2011
  8. 308 GTB
    11,719
    New Jersey
    Barry Wolinsky
    Right. Clean the bities out of that tube with a hanger or something otherwise your cockpit'll wind up a billabong.
  9. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,420
    Los Angeles
    Bill Karp
    GOOD JOB BARRY !!!!
  10. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Lol! :p:p
  11. 308 GTB
    11,719
    New Jersey
    Barry Wolinsky
    Piece of piss, mate!
  12. PAP 348
    Dec 10, 2005
    100,220
    Pap
    So cheeky. :eek::eek:
  13. jaticker
    Oct 27, 2007
    251
    tampa
    John Annis
    You guys were correct. A shot of air did the trick.
  14. 308 GTB
    11,719
    New Jersey
    Barry Wolinsky
    There you go! You blew those mossies back into the evaporator! They'll be back in a jiffy.
    Nah! You just broke up that clog, that's all. That's just regular maintenance of the AC condensation tube. Get into the habit of clearing all the drain tubes on your car periodically.
    Barry
  15. 308 GTB
    11,719
    New Jersey
    Barry Wolinsky
    Pap,
    My chief resident, when I was an intern, was from Melbourne. By the end of that year, I was speaking Australian! ;)
    Bazza
    (He never called me that. That I learned here!)
  16. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,420
    Los Angeles
    Bill Karp
    #16 wbklink, Jan 25, 2011
    Had to email a friend to ask...
    Hi Fiona,
    O.K. Mate please tell what (Piece of piss, mate!) means ?
    Cheers,
    Bill
    Easy!
  17. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Fantastic! :D:D
    Strewth!! You blokes are as Aussie as meat pie! :eek::eek:
  18. doppioexpresso
    doppioexpresso Karting
    Mar 29, 2010
    112
    Zürich, Switzerland
    Marc
    Thanks for this post guys! Had the same problem and fixed it for no money... unfortunately I have to get Katharina a pair of new Gucci Stilettos as they didn't survive the amount of whater leaking on them - AUTSCH!!!!
  19. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Perhaps you can claim them on your insurance! It works that way here, every good that's in the car is treated as if it was in your home. :D
  20. doppioexpresso
    Mar 29, 2010
    112
    Zürich, Switzerland
    Marc
    Ok, I shall try! thanks for the input
  21. mcypert
    mcypert Formula Junior
    Jun 7, 2012
    369
    Houston, Texas
    Mark Cypert
    Sorry to resurrect this post. Does anyone know if the 456's is near the same place as in 308 GTB's pic's? I'm 250 miles from home and hear water sloshing and almost no water coming out when I stop. I was under there today and didn't find it, but that was before I saw the pics. Will look again tomorrow.
    Thanks......
  22. G. Pepper
    G. Pepper Three Time F1 World Champ
    38,387
    Texas/Colorado
    George Pepper
    My 456M's drain was clogged with dead bugs on a long trip and it was HUGELY expensive. Not to unclog the drain, but to replace the ECU's that got ruined. The drain is easy to find: Just look for the water dripping. You can root it with something like a long US-spec oil dipstick, but to really get everything out, you may need to take the center console apart and go at it from the top. That's what had to be done with mine. It was 100% crickets, BTW: They crawl up the drain to get to the water.
    Cheers,
    George
  23. mcypert
    Jun 7, 2012
    369
    Houston, Texas
    Mark Cypert
    Thanks George. It was your experience that made me worry. Nothing inside is wet, but I'm not seeing any water coming out underneath, except a tiny drip down the side rail at about the end of the center muffler. I had the front right jacked up, so couldn't see where the drain hose came out or the origin of the water. 308's pics will probably lead me to it.
    I'm in Dallas and will be driving back to Houston and would not like to duplicate your problem.
    From what I'm seeing from the pics, the hose is in the passenger-side rail near the O2 sensors?
    Regards........
  24. mcypert
    Jun 7, 2012
    369
    Houston, Texas
    Mark Cypert
    Found it! It's in the blank spot in the passenger's-side frame rail, just like in 308's pic's. Not obvious, since the water was running down the rail and not dripping from the hose. I still couldn't see it but flicked some crud with my fingernail and water poured out like opening the spigot on an office water cooler. Gallons?
    This forum saved my bacon......Thanks
  25. 308 GTB
    11,719
    New Jersey
    Barry Wolinsky
    I'm happy to see you found the drain, Mark. All these drains need periodic maintenance.
    Barry
