Acceleration: F40, F50, Enzo, CGT & Veyron | Page 11 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Bill S, Aug 30, 2009.
  1. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    The HP vs MPH charts include everything except aerodynamics. You don't need to know torque if you know HP at all RPMs. HP is basically TQ X RPM. HP is the power to move the car and it is derived from torque.
    Regardless, it's much easier to compare the 60 to 130 MPH times so you don't get into the launch variables. A CGT is much faster than a EU F40 from 60 to 130. When you go faster, the increased drag starts to cut in and that slows the CGT compared to the F40. Then you can compare 60 to 180 times for that.
    And I agree that a US F40 is a little faster than a US F50, but not by very much from the data.
  2. F40 LeMans
    F40 LeMans Formula Junior
    Nov 23, 2009
    827
    #252 F40 LeMans, Dec 14, 2009
    So, how about the 100-200 kph?
    according to 60-130 mph would be faster the CGT... the HP vs MPH charts explain the Porsche winning always..
    instead, not for Euro "KPH" tests... contrarily, here, in most tests, the EU F40 is much faster than the Porsche...
    I agree : "When you go faster, the increased drag starts to cut in and that slows a car " BUT from 60 to 200 kph if not for
    the torque, what is the point? ;)
  3. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    Thanks for posting those data sheets. 100-200 kph is 62 to 124 mph, so 60 to 130 is even longer! We have much 60 to 130 mph data in the US. There is not much data over 130 mph.
    I think the 100 to 200 kph test for the Euro F40 is fast because it may only require one shift from 2-3. A 3-4 shift is not needed:
    60 to 130 mph requires:
    A 2-3 and 3-4 shift for the US F40 and Euro F40
    A 2-3 and 3-4 shift for the CGT
    62 to 124 mph (100 to 200 kph) requires:
    A 2-3 shift for the Euro F40
    More HP at lower RPM helps these times as shown in the graphs I posted. Torque is already considered when you graph HP vs RPM.
  4. F40 LeMans
    Nov 23, 2009
    827
    #254 F40 LeMans, Dec 14, 2009
    Bill,
    the 3-4 shift is not the point.
    You can take a segment without gear shift, and the point is the same.
    Take a look, from 60 km/h to 180 km/h or 100 km/h to 180 km/h with the same number of gear shift...so. :)
    Take a look at 120-180 km/h both. Same ONE gear shift.
    I've some others km/h tests of these cars both, and is easy to verify it.
  5. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    Yes, the Euro F40 in that test does look faster than a US F40:
    Euro F40: 0-124 MPH = 11.0 sec (no 3-4 shift?) from Auto Motor Sport test
    US F40: 0-124 mph = 11.7 sec (3-4 shift) from fastest R&T test
    CGT: 0-124 mph = 10.0 sec (from extrapolation using C&D test) with 3-4 shift.
    The CGT data you posted is much slower than the CGT data we have in the US. I'm not sure why.
    Given the large HP difference between the CGT and F40, similar aerodynamics under 124 mph, and a 400 lb or so weight difference, I would still expect the CGT to be faster than the Euro F40. The US CGT data seems to show that.
  6. F40 LeMans
    Nov 23, 2009
    827
    We should do, a good Torque/Gearing chart and than put all by x./tonne.
    Only after that I must explain the point.
    BUT I have not time.
  7. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    Can you provide us with GPS data on your car? This one is very good...
    http://www.performancebox.co.uk/
    I'll find some real GPS data for the CGT I can post.
    The graphs I posted consider Horsepower, Torque and Gearing. They are true power vs speed. I used all of that information to make those charts.
  8. F40 LeMans
    Nov 23, 2009
    827
    #258 F40 LeMans, Dec 14, 2009
    Sorry but I don't use GPS. :)
    I explein it quickly. I'm referring about 175 kph (110 mph). We must had power/torque, gearing, weight difference, wheels/tire dimensions.
    @ 175 kph the CGT is really 8000 rpm circa in 3rd gear.
    @ 175 kph F40 is really (by gearing/tire dimension) really 6100 rpm in 3rd gear, too.
    tires are:
    CGT 2,26 mt
    F40 2,09 mt
    weight
    CGT 1473 Kgs
    F40 1254 Kgs
    gearing in 3rd + final ratio
    CGT 1.36 * 4.44
    F40 1.23 * 3.63
    How many HP are good for the F40, for the same results of CGT in the point? So.
    CGT is 604 hp @ 8000 = 604*716.2/8000 = 54.0 KGm
    54.0*1.36 * 4.44= 326 KGm
    326 KGm/2.26*2.09 (tires)= 301 KGm
    301 Kgs *1473/1254 (weight)= 256 KGm
    256 KGm is the TQ good for the F40, for the same result of CGT at the same speed. (anyway approximately)
    256/1.23/3.63 = 57.3 KGm of TQ
    57.3*6100/716.2 = 488 HP
    488 HP is the power @ 6100 rpm good for the F40,for the SAME result of CGT
    We have seen 496 HP dynoed EU F40...
  9. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    I agree. I considered all of that (except weight) in the charts by using mph vs. rpm in each gear. The charts are accurate.
    Real GPS data or accurate magazine tests are the only way to compare acceleration performance accurately. I will post GPS 100 to 200 kph for the CGT to help compare to your magazine test.
  10. F40 LeMans
    Nov 23, 2009
    827
    #260 F40 LeMans, Dec 14, 2009
    If you don't consider weight, how can....?
    That's normal------ a CGT advantage ;)
    but not the point...
    my point is what a F40 had for the same CGT point-result. That's 488 HP, when EU-spec are 500 hp able :)
    I agree for GPS data are anyway accurately.
  11. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Thanks for verifying.
  12. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    #262 Bill S, Dec 14, 2009
    Here is GPS 100 to 200 kph for my own CGT (6.7 seconds with 2-3 and 3-4 shift). This is a bit slower than the US magazine tests. But it is real data!
    It would be great if you can post real GPS 100 to 200 kph and 60 to 130 mph for your Euro F40! It may be very close to the CGT.
  13. F40 LeMans
    Nov 23, 2009
    827
    #263 F40 LeMans, Dec 14, 2009
    It would be great...... but I really don't know how fast is my car.
    Anyway, 6.4 s is good for customer EU cars, because SportAuto tested a Switzerland customer car with the same result as Auto Motor und Sport test.
    And, Nick Mason's car after 23.000 Kms could be quicker than that.
    Why don't use the FL 5 data for your comparo. And for the others data we don't have a proportion between C&D results and FL results. With accurate mode.
    Could be the only way...
  14. big.bryant
    big.bryant Formula Junior
    Sep 17, 2008
    681
    Boulder, Colorado
    Bryant
    Bill, another great thread, thanks for sharing your awesome collection and its data.
    Cheers.
  15. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Weight is important. The heavier a car is, the more power it needs to achieve a certain fixed performance. This bring into the question of the validity of comparing the acceleration of cars in different weight classes, and from a completely different era. As we know, up to this point, with time, the cars have gotten heavier, with more power to compensate.
    On the subject of feel, Autozine explains it better than the way I tried to do earlier on this thread:
    "It's also worth noting that the sensation of acceleration or 'pull' has some interesting psychological aspects. For instance, cars that rapidly increase their rate of acceleration can feel very fast when they may in fact be slower than cars that are more on/off in their response. Turbocharged cars generally have this rush of acceleration that comes on in such a way, creating a more intense sensation".
    That "intense sensation" is what does t for me. I have driven an F50 and an Enzo and whilst I agree the data says they are faster, but their acceleration wasn't as exhilarating as that of the F40.
    What I get from this thread is that for a car launched 22 years ago, the F40 is still an amazing performance car almost a quarter century later.
  16. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Great points to consider, in the real world.
    There is a significant difference from car-to-car, depending on whether one is running properly, is well-tuned or not, and whether all the aforementioned setup and conditions variables are equal. This is especially true of turbocharged cars and I have found that in both my ownership and testing of many other F40s the differences in performance output between them are starkly obvious in some cases, and you dont need a measuring device of any kind to determine same in those cases. Truth be told, if data being posted is being assumed as optimum, when it is in fact compromised by the aforementioned variables, then it is useless for arriving at any conclusions. I am 100% sure that because of real world situations some of the cars tested have in fact not been operating to peak performance, and some cars are 'quicker' (such as Masons) than others.
    Thank you for pointing this out F40 Le Mans.
  17. F40 LeMans
    Nov 23, 2009
    827
    #267 F40 LeMans, Dec 15, 2009
    Yes. weight is very important. And just the kms/miles running distance of a car, could make a difference.
    Here you are the graf comparo from the CGT you are shown for customers car (I think) and a customer car Switzerland F40 tested by SportAuto in 1990 (vs a Porsche 962), just as exactly the same performance af Auto Motor und Sport test.
    What we are able to see?
    Regardless the last gearshift af the F40, we are able to see that CGT was helped by a shorter gearing, so one compensates the other gears ratio, in real world.
    F40 has a longer one. Anyway the Ferrari is running faster when its TQ operating to peak performance (wiht a longer gear) and it dies in high band compared to the Porsche.
    The last gearshift is not the point, cause it run the 100 - 200 km/h in 6.4 secs.
    What's the point now? anyway we are talking, the Ferrari is little quicker in this segment speed crescendo, behind the total gearing, of both cars.
  18. F40 LeMans
    Nov 23, 2009
    827
    #268 F40 LeMans, Dec 15, 2009
    The point is that some cars tested are Factory press cars, with thousands of miles on their odometer. Some others are customers car with engines like new. Some others more, are customers cars frequently used. So...
    There could be little but important differences between them. We can only guess, but is simple verify that teh C&D CGT tested was a Factory press car, it was German registred and it was tested by some others magazines. Faster than other more fresh customers CGT.
    Like is simple verify that the Mason's car was a fast car, for their 23.000 kms on the odo. More than a fresh engine car like the Switzerland car tested by SportAuto... and so on.
  19. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Very important. This shows that we are not talking simply about numbers, but also of knowledge of the variables that stand behind those numbers. Without knowing the specific variables as they apply to any given set of numbers, you cannot use those numbers for any absolute conclusion. Even though the effect of those variables is a very small difference, it is often enough for some to claim (sometimes erroneously) that one car is faster than another, because we are talking of fractions of a second.
  20. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Thank you for illustrating this.
  21. F40 LeMans
    Nov 23, 2009
    827
    #271 F40 LeMans, Dec 15, 2009
    Is easy to gamble on the fact that some Factory cars are faster, but whenever they are, they are faster. This is evident, factory cars having thousands of miles and "maybe" being produced with top-end engines tollerances are regularly faster then others sisters cars, but customers cars.
    I am amazed as other cars, maybe customers cars (with thousands of miles on their odometer) that are quicker of other Factory cars. That's a proof, they are really faster :)
    When I had seen the Mason's car a bit quicker than the C&D CGT in the 0-170 mph comparo, it was really for me a proof, one more.
    FL tested his F40 years before, and, with a fresh engine and not the most accuate mode was slower than that day, as EVO was slower (with approx the same proportion) in their test with a 3/4000 miles CGT, owned by an English man for their long term test, compared to the Factory car figures. The F40 was faster then the CGT in both examples.
    So, behind that, there is a truth. And now it's easier to compare between them :)
    (All that for explain)
  22. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    Another thing to consider is gas octane. My CGT GPS run was with 91 (R+M)/2. The CGT is noticeably faster with higher octane fuel, and that may have been present in some of the CGT US tests.
    But from your data, I think we can safely conclude that the Euro F40 in that magazine test was faster from 100 to 200 kph (62 to 124 mph) with one shift then my personal CGT that I tested with 91 octane gas and two shifts. That's mainly because of the low weight of that particular F40, it's extra HP with no cats, and its better gearing in that range with just one shift.
    F40 LeMan, can you publish other magazine data you have for the Euro F40 so we can learn more about that car's performance?
  23. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Yes, when data alone is king without regard to variable you've described we run the risk of being 'baffled by science'. Look at these varying results, and note they are ALL for Eu cars. care to explain?
    Top speeds: 202.6 mph* / 199.4 mph**
    Acceleration:
    0-60 mph:
    4.4 sec* / 4.4 sec** / 3.9 sec***
    0-100 mph 8.0 sec* / 8.1 sec** / 7.8 sec***
    * Tested by Quattroruote
    ** Tested by Auto Motor und Sport
    *** Tested by Fast Lane
  24. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,448
    Will Tomkins
    Normal variation to be expected taking into account:
    Air temp & pressure affecting power output
    Variation between different engines
    Differing all up weights
    Driver technique
    Tyre temperature affecting grip plus the possibility of one set of tyres having been scrubbed in differently to another
    Measuring error (unless specified +/-)
  25. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    Using 60-100 to remove some launch variables:
    3.6*
    3.7**
    3.9***
    These are pretty close and noticeably faster, on average, from the 4.1 and 4.2 seen for US cars, especially the 3.6 and 3.7.
    Joe, do you have more numbers from *, ** and *** ?
