Acceleration: F40, F50, Enzo, CGT & Veyron | Page 28 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Bill S, Aug 30, 2009.
  1. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #676 Napolis, Mar 26, 2011
    Yes they are aerodynamic devices that trim out wake turbulence caused by the wing which is a regulated size and configuration.
    I do think it's important to remember that sports cars are designed to go around turns and that the numbers they can generate in downforce and lateral grip are important and IMO more important than 0-60 or 1/4 mile times or even VMAX. P 4/5 Competizione's VMAX is "only" about 160 mph and it has "only" 430HP. (HP is restricted by air restriction) It also has minimum weight of 2750 lbs. (It carries ballast to reach that) but because of the numbers I spoke of it can go around turns and a race course reasonably quickly even one with a long straight.
    Note the forces in this photo.
    Note that it goes through many turns in this video without lifting the throttle. I wouldn't suggest trying this in an Enzo.
    [ame]http://www.youtube.com/watch?v=cwN-h7ykYR0[/ame]
  2. RICE RACING
    RICE RACING Rookie
    Apr 20, 2010
    38
    Australia
    Peter Giljevic
    And what exactly does this have to do with a Ferrari F40? ^
  3. RICE RACING
    RICE RACING Rookie
    Apr 20, 2010
    38
    Australia
    Peter Giljevic
    Completely stupid comparison sad to say, why? I'll let you work that one out.
  4. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    #679 JeremyJon, Mar 27, 2011
    that's because YOU are missing the point, about equalizing comaprison of cars not side-by-side, made by someone with obviously better insight then yourself ...minding you manners here would be something to try also!
  5. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,323
    Bournemouth, UK
    Good points! On the other hand though, an Enzo is massively more powerful and almost 10 years older...
  6. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #681 Napolis, Mar 27, 2011
    That's the point. Even with much more HP, unless that HP is allowed to work, (Traction enabled by Downforce) it's useless. Around a Race Course P 4/5 C would leave all of these cars FAR behind. (even in fully street legal configuration) At the Ring an Enzo couldn't even finish one lap being pushed without over stressing it's shock absorbers.
    P 4/5 Competizione has so much downforce that it doesn't need Traction Control in Dry conditions. The Ferrari F430 GT 2 does. On the street downforce is very important especially low speed downforce as it makes cars safer to drive around turns. All of the cars compared in this thread are designed to produce downforce. The F40, especially an LM version or a street version fitted with wing/canard/fences, and there are several that are, produces a lot of downforce which makes it a lot faster around turns and improves air flow through the engine compartment which lowers under hood temperatures and engine inlet temperature which produces more HP. The movable wing on the CGT and Veyron are downforce devices that crank out to allow higher VMAX. My point remains numbers that also matter and IMO are a lot more interesting when comparing sports cars are as opposed to 8 second 200 mph 1/4 mile Evo's are downforce and lateral grip. P 4/5 Competizione is fitted with sensors that measure and report these numbers in real time and enable us to race the car efficiently. A skid pad can measure lateral grip and many magazines report them when testing Sports Cars. I have measured the Downforce of an Enzo in a wind tunnel, as an aside it's no where near as high as reported in Road and Track, and it's an interesting one to compare with P 4/5 Competizione's.
    This is Ferrari Chat. This isn't EVO Drag Chat. Ferrari's are Sports Cars. Even 20 year old Ferrari F 40's were built to produce lateral grip and downforce and comparing it's numbers to an Enzo's might be instructive.
    Bill has an Enzo and a CGT. How about testing them on a skid pad and measuring lateral grip. Many here have F 40's and could do the same test.
  7. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    The current issue of Top Gear has an interesting article on the new Pagani Huayra that explains it's computer controlled active aero systems which are quite amazing and not only help downforce and VMAX but also help anti roll/anti dive and braking. It will be interesting to see if the the new "Enzo" uses this technology. The Enzo/Veyron and CGT have active aero but nothing like this. Even though it's 20 years old the F40's aero especially as developed on the F40 LM is still very impressive. Does anyone know F 40/ 288 GTO/ Lateral G numbers? (Skid Pad)
  8. gsm348
    gsm348 Karting
    Nov 7, 2003
    138
    Chicago
    Greg
    C&D tested the F40 at 1.01g
    http://www.caranddriver.com/features/08q4/rocket_sleds_the_best_performers_from_50_years_of_car_and_driver_testing-feature/orbitals_page_2
  9. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
  10. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Just awesome! Thanks.
  11. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    Ok, this thread was about straight line acceleration, but here's my 2 cents on lateral acceleration, which is harder to measure.
    Modern street tires for a 3,000 lb car are limited to about 1.1 G. If you put racing slicks on an Enzo or Carrera GT, you'll likely see 1.5 G or more. We've already seen a Carrera GT compete with GT cars when using racing slicks and no other changes.
    A Carrera GT holds the production category flying speed record at the Talladega Superspeedway with special Michelin Pilot tires:
    http://www.rsportscars.com/eng/articles/record_carrera.asp
    Put good tires on an Enzo and tweak the suspension a bit, and you'll likely see 7:15 or better on the Nurburgring. A GT2 RS can even do 7:18!
    Road and Track compared ALMS GT race cars against their production counterparts in their November 2010 issue. They measured lateral G in turns 5 and 6 at Miller Motorsports Park. Here's what they found:
    BMW M3/M3 GT: .96/1.50 G
    Corvette ZR1/C6.R: 1.17G/1.52 G
    Ferrari F430/F430GTC: .96/1.49 G
    Jaguar XKR/XKR GT: .91/1.45 G
    Porsche GT3/GT3 RSR: 1.11/1.56 G
    In my opinion, tires have the most significant affect on lateral G.
  12. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
  13. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    Here's how an Enzo compares to a CGT at higher speeds. The CGT had a jump, but the Enzo quickly made up for that. I think you would see cars like the 458 be even further behind. The Enzo is a lot faster than the low-speed numbers show. After all, it goes 220 mph+ !
    [ame]http://www.youtube.com/watch?v=ceO2bBTnJOQ[/ame]
  14. source
    source Formula Junior
    Dec 20, 2010
    392
    Australia
    Michael
    Case and point.
  15. RICE RACING
    RICE RACING Rookie
    Apr 20, 2010
    38
    Australia
    Peter Giljevic
    After some inspiration from a Ferrari F40 owner (ex owner) Peter Pless in Australia I finally got around to absolutely smashing the Ferrari F40 100kmh to 200kmh figures, easily dominated the USA example bill posted up and all of the European data I could find as well.
    Results posted here > http://www.rotarycarclub.com/rotary_forum/showthread.php?t=14704
    My RX7SP is in full street set up, normal pump petrol (water injected) and more of a handling car than a straight line car, but still.
    Bill, I'd like to see 100kmh to 200kmh from the CGT and the Enzo if you can please post it up as you did annotated for the F40 you tested.
    Thanks.
    p.s. The rx7 is no one hit wonder, been running at this level for over 20,000km, and have had it to 211mph :)
  16. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    #691 Bill S, Apr 27, 2012
    My most recent Enzo test is shown below after the engine rebuild. 100kmh to 200kmh in 5.8 seconds.
  17. RICE RACING
    RICE RACING Rookie
    Apr 20, 2010
    38
    Australia
    Peter Giljevic
    Thanks very much Bill, that is a ROCKET!
    Would you be able to send me a clearer picture of that test please? [email protected]
    Also what was the weight when you ran it.
    I read all about your precision engine rebuild on the Enzo, it makes me happy to see an owner of such cars getting down and doing the hard work like that what you undertook.
    Best Regards.
    Peter
  18. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    #693 Bill S, Apr 27, 2012
    Approximate weight during that test is 3130 lbs. Here's the Y-Axis magnified:
  19. RICE RACING
    RICE RACING Rookie
    Apr 20, 2010
    38
    Australia
    Peter Giljevic
    How much do you estimate the power is now? or closer to factory rating v's before when the motor was a bit tired.
  20. MaxMcQueen
    MaxMcQueen Karting
    Jun 23, 2010
    124
    Max
    #695 MaxMcQueen, Mar 3, 2013
    Few days ago, this is what I found on a Australian or UK (dont remember) car website talking about Ferraris, it seems a gps test and sounds so fast. The car was also dyno'ed 420 whp....
  21. 85886
    85886 Karting
    Feb 22, 2012
    134
    The best 100 to 200 km/h times of OEM cars from magazine tests I've seen:
    10.2 s GTO
    6.4 s F40
    7.5 s F50
    5.9 s Enzo
  22. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    #697 Bill S, Mar 3, 2013
    Those numbers don't look like they're for an F40 unless it's very high boost. Here's what I got on my US F40 with a slight downhill at the start. I also included the old C&D test for comparison...
  23. MaxMcQueen
    MaxMcQueen Karting
    Jun 23, 2010
    124
    Max
    The car was a bone stock early car... thanks for the scan.
  24. MaxMcQueen
    MaxMcQueen Karting
    Jun 23, 2010
    124
    Max
    I think the reason was the bonus of power. Octane Magazine said about:
    Ferrari quoted 478 bhp for catalyst-equipped F40 and we all know that Italian horses are usually bigger than others. But with the early cars not fitted with catalytic converters, which were quoted 486 bhp, the power is actually nearer to 500 bhp. That's a nice bonus and it's why pre-cat cars are the most desiderable.
    American spec are not as desiderable: less power, more weight because of the extra crash protection, catalysts, adjustable suspension, additions to the bodywork, strange seatbelts and so on.
  25. F40 LeMans
    F40 LeMans Formula Junior
    Nov 23, 2009
    823
    Max,
    Thanks for the test you posted, it's very helpful. I agree with how Octane magazine published about power and weight.
