Acceleration Sensors Location? | FerrariChat
Discussion in '360/430' started by KILOCHARLIE, Feb 23, 2018.
  1. KILOCHARLIE
    KILOCHARLIE Formula Junior
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    I have a sensor error but no idea where items 1 and 6 are on the below diagram, apart from they are in the front compartment somewhere. Anyone have any ideas please?
  2. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    #2 mike01606, Feb 23, 2018
    One is under the scuttle panel where your windscreen wipers are. It can be accessed through the back of the front compartment, behind the membrane.
    The other is in the engine bay under the RH engine bay trim panel bolted to the top of the upper chassis rail next to the cat temp ECU.
  3. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
  4. KILOCHARLIE
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    Many thanks. Any idea where under the scuttle it would be please? I've had a really good look with the membrane off but struggle to find it.
    Also there are apparently two at the front (1&6 on the diagram). Any idea where the other front one is at all please. The rear is #16 on the diagram but thanks for the helpful photo.
  5. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Sorry no pics but I came across one either working on the brake module or the battery disconnect switch so start looking close to them.
