Access Panel | Page 2 | FerrariChat
Access Panel
Discussion in '308/328' started by shashi27, Jan 19, 2019.
  1. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,831
    Cerritos, CA.
    Easy if you have a lift but for people who doesn’t have a car lift and has a history of lower back problem, access panel is a plus and I still know that access panel is still better than no access panel, it may not be original but so what?
  2. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Just to be sure that we are all on the same page:
    Creating an access panel behind the seats that does not remove the horizontal structural member that is part of the frame will only show the lower 1/2 (2/3 ?) of the engine. Anything that you could access through that panel will be hidden behind the exhaust as I understand it.
    Rifledriver likes this.
  3. absostone
    absostone F1 World Champ
    10,169
    ill agree with rifledriver on the front header removal. the rear is way more difficult. but I also have a lift.
  4. Rifledriver
    37,288
    Don't confuse this situation by applying logic.
  5. Rifledriver
    37,288
    Lift or no lift it will not matter.
  6. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Story of my freakin' life. ;-)
  7. GordonC
    GordonC F1 Rookie
    4,166
    Calgary, AB, Canada
    Gordon
    I'll disagree with you on several points. First, the question of whether there would be anything gained on a 308 by having possibly easier access through a bulkhead panel isn't really a matter of opinion - there are only a few components in that location, they could be accessed from above, below, or through a panel - it's not an opinion that there are exhaust manifold bolts, a starter, a dipstick tube there, it's fact. If those can be easily accessed from above or below, then access isn't easier through a potential panel - also fact, not opinion.
    Second, I'll disagree with your suggestion that Rifledriver should take his input elsewhere just because you don't like his manner of presentation. His input is invaluable to this forum, even if he presents it straight, doesn't pull punches, is rude - however you want to call it. I'd rather have a professional with 40 years experience on these cars giving me a rude correct answer and guidance, straight up, than worry about my feelings getting hurt. I have been on the receiving end of a few Rifledriver corrective posts - and rather than getting offended, I consider them learning opportunities, as a DIY person trying to learn the right way to maintain this car. I'd love to have an opportunity to buy Brian a beer as thanks for his participation in the forum - we're all the better for it.
    It's not much different than the machinist who ran the machine shop in our engineering faculty when I was studying mechanical engineering - I learned a huge amount from him about operating all the various tools and machines correctly, that wasn't part of the formal engineering curriculum. I'm no machinist, but I know how to use a lathe, mill, etc etc, and if he saw someone doing something incorrectly and called someone a f'ing idiot, then chances were pretty good that the person was actually being a f'ing idiot - and after calling someone out, the machinist would then explain and demonstrate what he was doing wrong, and the right way to do it.
  8. Jonny Law
    Jonny Law F1 Rookie
    3,210
    Over yonder.
    IT Guy
    Now I remember why I stopped posting to this forum. The holier then thou attitude of the purist that felt if you weren't doing it the Ferrari way, you should be beaten in to submission. Or in this case trolled to death.
  9. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,286
    Black Forest Germany
    Martin N.
    The first time I saw such an access panel on a Ferrari was on the 288 GTO. I found it charming, doing a cambelt or waterpump job from inside the passenger room.
    When it's cracked or has spit out out the sniffer plugs since their inside threads rusted away.
    Regarding 'rifledriver'.
    Here we go again! :)
    Best from Germany
    Martin
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,667
    San Carlos, CA
    Mitchell Le
    Jonny,
    There is no holier than thou attitude here. Just us who have done it before. It is your car, if you want to cut a hole in it, please do so. Then come back to tell us what you have learned. I'm happy to listen.
    Best wishes,
  11. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    some urraco and jalpas have an access panel to get to the front set of plugs easier. its also an transverse v8. I haven't personally worked on one but the fellows that do appear to prefer going through the bulkhead rather than over the top.
  12. shashi27
    shashi27 Formula Junior
    Jan 7, 2006
    988
    Long Valley, NJ
    Shashi
    Guys. It’s was just a question. I thought the topic had more or less been closed a while back so a bit surprised it has continued to be discussed.
    Some see value. Others not. Its all good. I value all the input.
    It’s not like I am challenging the external timing belt question. .
