Access to door courtesy bulb | FerrariChat
Discussion in '206/246' started by mar3kl, Aug 14, 2019.
  1. mar3kl
    mar3kl Formula Junior
    Nov 17, 2011
    474
    Silicon Valley
    Mark
    So I successfully replaced the red-lens door courtesy bulb with an LED - works great. I happened to have the door trim panel off in order to adjust the latch, so I got at the fixture that way. Is there a way to change the bulb without taking off the door panel? Somehow pop the red lens off from the outside? It didn’t seem like it but if I ever just want to change the bulb I’d rather not deal with removing the trim panel. Getting the door pocket screws aligned with their threaded holes was a real PITA.
  2. racerboy9
    racerboy9 F1 Rookie
    2,682
    I think taking off the door panel is the only way. With an LED bulb you should be set for life. I use a scratch awl or small drill bit to line up the holes.
  3. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Gotta take the door card off, there are one way tabs on the housing that hold it in place and prevent removal
