Accessory Pulleys/Ignition Campaign | FerrariChat
Discussion in '348/355' started by vvassallo, Jun 2, 2008.
  1. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    I was thinking about some tuner tips for the 348 and wondered about changing out the accessory pullies to smaller diameter versions. Has anyone done this or thought about it? It might makes us some HP by reducing parasitic drag. This is "found' HP without taxing the engine output more. I am not exactly sure which pullies this affects, but you really only get a single shot at it because I would not want to drop the engine more than once. :) Unless we can get to the pullies in the car. Minis get about 5% power gain from this mod. Hey that's like 15+ HP for us!
    Also, tuners fit a hotter ignition system for some extra power. Can we do this? This generally means hotter coils, better spark plug set and maybe plugs? Are there upgrades to be done or did Ferrari already tap this vein?
    My logic is this. If my car measures 245 RW HP stock (on my dyno - remember everything is relative) and the rating is 312 from the factory, that is 67 HP of parasitic drag - over 20%. If we can reduce the "overhead" we can make the drive train more efficient. I would think that a rear engined RWD car should be a lot better than what my measurements are showing. Heck, my Corvette lost less.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yeah but I don't think you wanna go with smaller pulleys. From what I have read on the pulley swaps is that they go with an under drive pulley = larger diameter pulley, so that the a/c, alternator, and water pumps turn slower. If I'm not mistaken the pulleys are also made from 6061 aluminum so that they weigh less.
  3. plugzit
    plugzit F1 Veteran
    7,795
    Redondo Beach, CA
    Bruce Bogart
    I seem to recall that the main benefit is if you can spin the water pump slower (which would be a major hassle with a 348 unless you removed the impeller and used an electric pump instead), and the alternator mainly produces drag as a result of its' charging and that's a constant, and the ac cuts off at full throttle anyway. I'm sure the hairdressers could get a benefit from spinning the power steering pump slower. All negativity aside tho, I'd love to see it done on the alt and ac, and see what result it gets.
  4. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Not a bad idea vince...... :)!
    I think vince means a smaller crank pulley which would do what you said.... make the rest of them larger and hence slower .... ;)
  5. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    I was thinking of this too...on my STi I went with all VERY lightweight pulleys but kept same diameter. I'm not a big fan of underdriven pulleys, especially on the 355. I want all the amps and cooling capacity that's available...
  6. Dr.T348
    Dr.T348 Formula 3
    Jan 8, 2004
    1,599
    Chicago NW Burbs
    Richard T.
    I think you want to look at the back end. Smaller, lighter flywheel!
    Water pump is internal and on the timing belt. Just unhook the a/c belt like the challenge cars did.
  7. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Here in Arizona, A/C is really important, even early in the mornings in summer (you can go 4-6 weeks without ever getting below 80degF!!). So I'd be concerned with slower compressor speed, but I suppose you could also put a smaller pulley on the compressor. Would be interested to see someone try this!
