Accusump or not? | Page 2 | FerrariChat
Accusump or not?
Discussion in 'Technical Q&A' started by stratos, Oct 20, 2005.
  1. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    #26 enjoythemusic, Oct 10, 2006
    It adds/changes the baffling. It is easy to install once you have the pan off and you need to drill two holes to rivet a pair of 'wings'. Really simple stuff but last thing i need is oil starvation while on the track.
    Pic below is from Nick Forza.
  2. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Thanks for the info . . . looks like no need to split the motor/g'box and do anything with the upper windage tray hopefully.
    Please post back and let us know how it works.
    Sean
  3. Dr Tommy Cosgrove
    36,700
    Birmingham, AL
    Tommy
    My 84 308 REALLY need help on the track with the right-handers too. Interestingly, it was never a problem before I started using track rubber. I installed the accusump and I give it about a C+. It's worth having but the problem didn't completely go away.
  4. enjoythemusic
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Well, i overfill oil a pint and use Mich Pilot Cup rubber (180 wear rating). According to my data acqusition system (Traqmate) i can only pull and sustain 1G in a turn, a bit more (1.2G) if the road elevates. Am planning to use Hoosier R06 next year and am looking to 'cure' things before they happen.
    What rubber are you using? Want to avoid starvation. Many thanks as all help is always appreciated.
  5. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Sean,
    Yes, I installed a single line from the Accusump to the oil filter housing to where the sending unit was, then welded another fitting for the sending unit. The Accusump brings 3 features: 1. prelubes the engine before starting, 2. adds an additional 3 quarts to the system, and 3. prevents oil starvation during hard cornering. I also added a forward oil cooler.
    In addition, if you are serious about tracking your car, I would suggest adding Nick's baffles.
  6. Dr Tommy Cosgrove
    36,700
    Birmingham, AL
    Tommy
    Kumo Victoracers - shaved and heat cycled.. BEST tire for non comp track days for the money.
    Hoosiers are light years better but cost more. At TigPrix the Victoracers may last two days if you are lucky and I just can't spend the extra on Hoosiers for that little lifespan (even though I would love to try them). Barbers Motorsports will see about 5-6 track days with the same Kumos.
  7. enjoythemusic
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Many thanks. Went with Pilot Cups as was afraid of the $$$ for Hoosiers over the 25+ track days a year. Seems the Cups wear like iron as i have plenty of tread left. Will check out the Kumos and decide in spring 2007. Again, many thanks.
