Ack! My 348 is peepeeing (just a little) | Page 2 | FerrariChat
Discussion in '348/355' started by Chupacabra, Nov 21, 2011.
  1. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    FYI, my car did not need the flange. It looked as though it either had a clutch job earlier and this stuff was updated, or my model run got the updated flange part. I did order it, but I am hanging on to it just in case. It IS a Ferrari, afterall. :)
  2. Chupacabra
    Chupacabra F1 Rookie Owner Rossa Subscribed
    Sep 30, 2005
    3,584
    Behind a drum kit
    Mr. Chupacabra
    OK, so, with the help of my always mechanically eager Cousin, I got around to getting the pumpkin off the car. Here's what we found:
    I was definitely losing both gear oil and clutch fluid.
    Triple seals are shot. The aft seal (relative to back of car) is loose on the shaft, just kind of spinning and actually gapes out to one side when pushed on, even slightly. The center seal is also quite loose and has a 1/4" section that looks like something sheared a few mm off of the seal in sort of a crescent shape. The front seal is also a little loose, and they all seem kind of hard, though this is my first 348 clutch seal rodeo, so that may be false perception. I got a shot of the seals/shaft, but I couldn't get a detailed enough photo of the whole deal, so it's of little use. Triple seals ordered.
    The T/O bearing looks to me to be in good shape, except for the seals. Pried all of those out (again, quite hard and the seal in the bearing itself was very brittle) and ordered new ones. The bearing was pretty wet when we pulled it, which, again, could be normal, but there was fluid outside on the casing before we pulled it from the flange. I don't feel like that is normal. I'll include a pic of that, and also a (slightly blurry) shot of the back of the bearing, which has four pressed detents. I haven't seen another T/O like this one, OEM or otherwise, advertised anywhere. Any ideas which one this is and how old it may be?
    Clutch fingers look good, I'm happy about that!
  3. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Uh yeah, those seals have had it. It is not normal for the bearing to be wet with fluid.
    I would just replace the t.o.b seals, o-rings, and triple seals. Especially if the bearing feels something. I would also change the o-rings behind the slave cylinder while you are in there, as they are probably hard/ening. May wanna check the ring nut for the transfer gear too. Mikey has a picture of it in the link to his thread.
  4. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Go through my thread from start to finish (the one I posted onm page 1 here) and you will see all the seals I changed, including the triple seals.
    Once those are all changed, you should be fine. Your TO Bearing looks just like the mine.
  5. Chupacabra
    Sep 30, 2005
    3,584
    Behind a drum kit
    Mr. Chupacabra
    Thanks, Mike, I have poured through your thread (and Ernie's) a few times now :) Thanks for posting this stuff, guys!
    Mike, your T/O bearing doesn't have the four little dents, does it? Did I just miss 'em?
    Here's what I ordered -- maybe a bit of overkill, but I don't want to have to pull this thing off again right away, and I'm assuming that all of the seals currently in there are roughly the same age:
    137249 X 3
    139438
    138387
    151822
    131747
    121813 X 2
    143178
    121651
  6. Chupacabra
    Sep 30, 2005
    3,584
    Behind a drum kit
    Mr. Chupacabra
    BTW -- a warning for anyone doing this job with an SS front lip or a slightly lower ride height. If you are using jack stands, MAKE SURE you have a spotter in the front to tell you when you're out of room so you don't jam your spoiler into the floor while you are jacking the car up to slide the stands in. I was lucky enough to think about that right before we went to work, and it was VERY close. I was lying on the floor telling my cousin how many millimeters we had to work with :) I can see how someone could dig it in pretty easily if you are just working at the back trying to get enough clearance to get the stands in.
  7. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Hey Chup, don't forget to take pics and post up your how-to in this thread so it can help out the next brother. The more how-to threads we have the better it is for the Brotherhood. Plus you may come across a neat little trick the rest of us may have not thought of that can save someone time.
  8. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    I think you're right, I didn't see those grooves in mine either, but the rest of it looks identical.
    Very smart move - replace everything you can get at, that is what I did. I think my triple seals were still in good shape, but I change mine out regardless.
  9. Chupacabra
    Sep 30, 2005
    3,584
    Behind a drum kit
    Mr. Chupacabra
    Will do! Unfortunately, my camera battery was dead yesterday for the dismantling phase, but the next stage will be well-photographed! :)
  10. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    When it's time to put the pumkin back on you'll see you have 2 concentric splined shafts to deal with. Moving the ring gear back and forth as you push the pumpkin on will help align the inner shaft. I put the car in 5th gear, handbrake off (on a flat surface, of course) and rocked it a little forwrd and aft on the tires (I didn't jack it up....once the bumper and muffler are off it's easy to get to) to rotate the outer splined shaft to get everything to mesh. Make sure it's in neutral and the handbrake is on the first time you start the engine just in case the install didn't go right and the clutch won't disengage. Don't want to drive through the house.
  11. Chupacabra
    Sep 30, 2005
    3,584
    Behind a drum kit
    Mr. Chupacabra
    OK, almost done...
    Can anyone tell me how #151822 goes in the back of the slave cylinder? Does the groove go to the front of the car? I can't imagine it goes any other way, but I can't get it to stay in there to save my life!
    Also, I forgot which way the ring scraper (#138387) goes...which side faces the diaphragm? I'm having a tough time getting it in at all. I'm starting to wonder if I don't have an oddball T/O :)
    May be obvious, but I want to be darn sure!
  12. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Part # 151822 should go right in and stay put.
    Have a look at this post and see if it helps.
    http://www.ferrarichat.com/forum/showpost.php?p=139934886&postcount=165
  13. Chupacabra
    Sep 30, 2005
    3,584
    Behind a drum kit
    Mr. Chupacabra
    Thanks, Ace...I'm having a hell of a time getting it in there. It's like the seal is too big. After examining the previous seal, the new and old parts are not alike. I wonder if it's possible that my cylinder is a bit different somehow, maybe an older one. Don't know if that should make any difference.
    To make matters worse, my triple seals refuse to shrink down...I tried the plastic and hose clamp trick, but to no avail so far.
    ARGH!! The ring/scraper doesn't want to fit, either!!!!
  14. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Strange....can you snap a pic of both the old seal and the new seal side by side and post it here?
  15. Carbonio
    Carbonio Formula 3
    Dec 1, 2009
    1,142
    In my time working as a parts professional at a Porsche dealership the joke was...
    "if you have a Porsche that doesn't leak oil, you have a Porsche without oil."
  16. Chupacabra
    Sep 30, 2005
    3,584
    Behind a drum kit
    Mr. Chupacabra
    I finally, after several hours of trying, got the thing to give up and just go in. I had to use a pick to press the seal down into the groove and even then it was quite a chore. Glad its done. This is the old seal -- I couldn't get the camera to focus well enough, but where 151822 is asymmetrical, this one is perfectly uniform on both sides:
  17. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Glad to hear it.
  18. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Very strange...I had that seal installed in less than 10 seconds...glad you finally got it.
    Did you change out the other two seals in the TO bearing, or just that one9
  19. Chupacabra
    Sep 30, 2005
    3,584
    Behind a drum kit
    Mr. Chupacabra
    Yes and no...still working on the ring scraper -- getting ready to go on stage, so I had to stop the car fun for the evening :) both of the others are in and looking good, though!
    Hopefully, the triples will have shrunk back down in the AM and I can get her back together and bleed the clutch. Then drive the hell out of her!
    Thank again for all the help, everyone! This is my first real ferrari maintenance job, and
    the support system here did not disappoint! I owe ya!
  20. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    You have to be patient with the triple seals...they don't shrink down right away...I tried squishing them down with my fingers, then eventually just wrapped plastic and hose clamps and kept it that way for a few hours. Then I changed the position of the plastic and the hose clamp for a few more hours just to be sure I got the entire surface of each seal.
  21. Chupacabra
    Sep 30, 2005
    3,584
    Behind a drum kit
    Mr. Chupacabra
    OK! I'm on the right track, then :)
    BTW, Remo Ambassador-weight clear mylar drum head film works very well for sliding the seals on! Diplomat-weight clear heads are even thinner and may work better.
  22. Chupacabra
    Sep 30, 2005
    3,584
    Behind a drum kit
    Mr. Chupacabra
    Got the bell housing on earlier today. I used a nice little trick to make it much easier...get one person under the car and one person standing. Give the person standing a guitar strap or similar hefty, wide strap-type thing to wrap under the bell housing. That way, it's easier to hoist up and wiggle a bit, plus you can easily manipulate the ring gear and adjust the whole unit's "altitude" a bit more. Worked well! I'm sure it has been done before, but I guess it's worth reiterating!
    We had a bit of a moment with the T/O bearing/slave cylinder. Seems the first time it went back on, it developed a vacuum and refused to slide. It took two sets of hands to get it off, but we prevailed and now it's working flawlessly. Another thing to look out for!
  23. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Chup - nice job, glad it's settled.
