Actual Weight of the US Rear Bumper | FerrariChat
Discussion in '308/328' started by miketuason, Nov 6, 2013.
  1. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,809
    Cerritos, CA.
    #1 miketuason, Nov 6, 2013
  2. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    I think the front bumper is about 42lbs. I have only weighted it after packing it for shipping so I am guessing a bit.
  3. miketuason
    Feb 24, 2006
    15,809
    Cerritos, CA.
    Almost 90 lbs between the two bumpers, that's a lot of weight.
  4. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,596
    Gates Mills, Ohio
    Jon
    ... and exactly where you don't want it.
  5. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,849
    Atlanta
    John!
    And don't forget the bumper shocks, they weigh a good 3.5lbs each.
  6. miketuason
    Feb 24, 2006
    15,809
    Cerritos, CA.
    Man, if I could only get rid of all those weight, that's like gaining 5 to 10 HP more, I think.
  7. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    For these car's HP/weight...if you got rid of the total 90 pounds it would be worth the equivalent of 7HP for acceleration purposes (has no effect on top speed). 7HP, would, at best, reduce the 1/4 mile time by one tenth of a second and increase the trap speed by .5 (one half) MPH.
    I can see doing the work if you want to change the appearance but if you are doing it for HP, I wouldn't wast the time. There is no way to ever notice that change. 400 pounds of weight loss might be worth talking about but it's still pretty minimal HP-wise. Even that would not provide a 1 second improvement in the 1/4 and again, no affect on top speed.
    Note - there is no set formula for how much weight change = one HP. It's varies depending on the power to weight of the particular vehicle. So dropping 100 lbs off a 3300 lb/240HP car is way different HP-wise than dropping 100 lbs from a motorcycle...or a tractor trailer! :)
  8. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    You'll notice the difference if you start attacking corners :)
    cheers
  9. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    +++++ 1
  10. myronx19
    myronx19 Formula Junior
    May 27, 2012
    653
    Toronto, ON Canada
    Myron Samila
    #10 myronx19, Nov 11, 2013
    Just curious, how much do the rear bumper spacers weigh?
  11. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    #11 cavallo_nero, Nov 11, 2013
  12. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    That doesn't look bad at all. Do you have a pic taken from a more level or look down angle? Getting rid of the metal diaper didn't hurt, either, though it does a good job of covering up my Ansa exhaust.
    BTW, where was the pic taken?
    Doug
  13. SMS
    SMS F1 Veteran
    Jan 7, 2004
    6,775
    Indy
    Bill S.
    One tenth of a second doesn't sound like much, but if your car runs 14.05 baseline, then the tenth is HUGE! :)
  14. Omnivore
    Omnivore Formula Junior
    Jun 3, 2011
    436
    Portland
    Matthew F
    Let's make it mandatory that all 308 guys with US bumpers get rid of them :>)
    Cheers to all that are. Moving the center of mass inboard reduces the polar moment of inertia. IOW more nimble and easier to rotate--back to the original design.
  15. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    #15 cavallo_nero, Nov 11, 2013
  16. StephenCushing
    StephenCushing Karting
    May 23, 2012
    133
    Norway
    Stephen Cushing
    Yep, all US cars should get rid of those goofy bumpers, you guys sure know how to ruin a good design !! euro style bumpers was the way Enzo made the car.
  17. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    Blame the nanny government regulators. At least my car doesn't have an 85 MPH speedo like some later cars did. :p
    Doug
  18. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    and when you remove the exhaust.....another 35lbs.
    Remove the spare in the tub...????
  19. miketuason
    Feb 24, 2006
    15,809
    Cerritos, CA.
    Imagine if we don't have to deal with the:
    US bumpers, Catalytic, and air pump, US 308 would b e sweeet. :)
  20. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    Since I moved to AZ, and have my car licensed as a collector car, I DON"T have to worry about cats, air pumps, or emissions at all, and have a wonderful new advance curve in my programmable dizzy. :)
    That factory muffler with the cats was a boat anchor. The Anza exhaust took a lot of weight off the car.
    If I ever put AC back on, it will be with a smaller lighter Sanden compressor, or something besides that heavy York.
    Still have to do something about the bumpers, though.
    Doug
  21. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,083
    FRANCE
    I've already written this, but according to Dirk-Michael Conradt's book ("Autos, die Geschichte machten, die Ferrari 308/328") in the annexes whereof there are a lot of actually measured weights, of the whole 308/328 family the 308 GTS QV was the model most affected by weight increases in its American-market version: he gives 1506 kgs as measured weight with tanks full for a US-market GTS QV, against 1355 for an Euro version (not on the same day or same scale), which makes a 151 kgs difference, or 333 lbs.
    Perhaps these figures are not absolutely exact, but they nevertheless gives an idea. It explains that, as I have just written a few days ago in the "Blu Scuro GTS i" thread, the measured performance figures of an US-Market QV are just a smidge better than those of an Euro 2 valve GTS"i".
    Those 333 lbs are the culprit...
    Rgds
  22. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    #22 AZDoug, Nov 12, 2013
    Little things add up.
    40 lbs here, 40 lbs there, 60 pounds over here, pretty soon you have some significant weight difference.
    The aftermarket VOXX aluminum wheels I bought weigh significantly more than the stock Ferrari wheels. I haven't put them on a scale, but the fcar wheels seem light as a feather in comparison, but the VOXX wheels are also wider, and 17" OD vs 14". Unsprung weight is not my friend, but they didn't cost much.
    Take weight off, put some back on....
    Doug
