added 15mm spacers to rear of my 348 and now the brakes squeak? | FerrariChat
Discussion in '348/355' started by tbsb9595, Apr 18, 2008.
  1. tbsb9595
    tbsb9595 Guest
    Sep 19, 2006
    105
    Largo, FL
    Tom Sweet
    After adding 15mm spacers to the rear of my 348 (with stock wheels) I noticed that the rear brakes squeak now.
    I used the longer bolts that came with the spacers. I don't see why this would happen. Has anyone had this happen before?
    If so how did/would you fix it?
    TIA
  2. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,328
    Palos Verdes
    Vince V
    No correlation. In removing the wheels and fitting the spacers, dirt/dust must have gotten in the calipers. Clean you rotors with brake cleaner. As long as you were using the correct bolts, there will be no clearance issues. Now which set of spacers did you use?
  3. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Pull out some of your bolts (one at a time) and see if they have any scuffing/scrapes on the ends...
  4. since15
    since15 Karting
    Dec 4, 2007
    132
    ATL
    Noel
    Got any pics before and after the addition of the spacers? Or at least after.
  5. tbsb9595
    tbsb9595 Guest
    Sep 19, 2006
    105
    Largo, FL
    Tom Sweet
    Thanks for the info! I used hill engineering spacers with matching bolts.
  6. tbsb9595
    tbsb9595 Guest
    Sep 19, 2006
    105
    Largo, FL
    Tom Sweet
    Thanks! I'll take a look at them.
  7. Gajac
    Gajac Rookie
    Oct 25, 2006
    15
    Good call
