Adhesive for inner door panel mounts? | FerrariChat
Discussion in '458 Italia/488/F8' started by MTribe, Jan 7, 2024.
  1. MTribe
    MTribe Rookie
    Mar 18, 2013
    24
    San Francisco, CA
    Anyone know what adhesive is used to adhere the plastic door panel mounting post plates to the door panel shown here?
    This is a carbon panel from a Speciale, but assume the glue is the same for all 458s... I found some threads referring to dealers re-gluing these, but haven't found indication of what adhesive it might be.
  2. Dave00
    Dave00 Rookie
    May 2, 2023
    30
    Dave abney
    Panel bond would hold or possibly some high strength automotive epoxy. The sell both at automotive paint supply stores
  3. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,805
    San Jose, California
    The exact same thing happened to me while removing a door panel off of a Speciale. High strength, two-part (mixable) epoxy (as Dave00 had mentioned) will do the trick. Make sure you sand both surfaces and thoroughly clean before applying the epoxy.
