Adjustable shock stuck? | FerrariChat
Discussion in 'Mondial' started by akorna, Nov 7, 2016.
  1. akorna
    akorna Rookie
    Jul 7, 2016
    41
    Virginia Beach
    Joe
    Folks,
    I've searched and found lots of info on the actuators for the "t," but nothing on the shocks themselves being stuck.
    With the actuators removed (actually a PO must have pulled them a long time ago...), I cannot rotate the geared shaft at the top of the LR shock in either direction. The RR rotates fine. I'm currently spraying with PB Blaster and tapping - no luck so far. Is it just time for a rebuild/replacement of the shock?
    Thanks in advance for any insight.
  2. alexion
    alexion Formula 3
    1,379
    New York
  3. akorna
    akorna Rookie
    Jul 7, 2016
    41
    Virginia Beach
    Joe
    Alexion,
    Thanks for the reply. The issue is not with the electric motor actuator, it's the shaft coming from the shock that the motor operates. I have heard of leaking shocks, but not locked, jammed, or stuck ones.
  4. porphy
    porphy Formula 3
    1,209
    LouisvilleKY/Switzld
    Randall Gatz
    You can have them rebuilt by the factory. Much less expensive than buying new. If, even, you can find them.
  5. akorna
    akorna Rookie
    Jul 7, 2016
    41
    Virginia Beach
    Joe
    Porphy,
    Thanks - you mean the Bilstien factory, right?
  6. Bevo
    Bevo Karting
    Feb 2, 2005
    191
    columbus ohio
    jack babbitt
    only place for Bilsteins is Delta Vee Motorsports,Kalamazoo MI ...deltavee.net
  7. porphy
    porphy Formula 3
    1,209
    Randall Gatz
    Yes. Bilstein somewhere in CA. As noted there are others but my experience is they are more expensive.
  8. akorna
    akorna Rookie
    Jul 7, 2016
    41
    Virginia Beach
    Joe
    Bilstein no longer rebuilds OEM shocks - here is the response I got:
    "Unfortunately we no longer refurbish OE product. Only thing I can suggest is contacting Ferrari for an inspection and/or possible replacement. Thanks.
    Juan Alvarez
    Bilstein Technical Center Lead
    ThyssenKrupp Bilstein of America, Inc."
    As Bevo said - Delta Vee will rebuild with lifetime warranty for $450 a shock.
  9. Rifledriver
    37,108
    And the Bilstein rebuilds sucked.
