Adjusting Cam belt Tension | FerrariChat
Discussion in '456/550/575' started by poffo, Feb 12, 2023.
  1. poffo
    poffo Rookie
    Feb 8, 2023
    42
    graham nicholls
    Evening,
    After sterling work with Hill Engineering tool, i have changed the belts and tensioner bearings and refitted and torqued the damper pulley.
    Rotated the crank 6 times and marks all still align, quite pleased with myself.
    Before i started the job i checked the tension on the belt using the Gates App - it is well liked on the Ducati forums.
    Before 95hz, did seem looser than i would have thought.
    Once i fitted the new belts and "released" the tensioner i got reading of 81hz.
    To increase tension i had to leverage the tensioner to compress the spring further, but managed to get exactly 126hz out of one side and 120hz out of the other. Car is a 1999 550, and i believe 126mz is the correct tension
    Is that the correct way to adjust the belt tension ?
    Thank you
  2. tazandjan
    39,058
    Ferrari updated the procedure on the 612 (also an F133 engine with the same belts) to use the sum of the frequencies on the two spans on each belt.
    F456M likes this.
  3. poffo
    poffo Rookie
    Feb 8, 2023
    42
    graham nicholls
    Thank you for this.
    So it needs 4 measurements in total !! Do they make it difficult for any specific reason....
    So my 81hz on the longest stretch probably wasn't actually far out.
    Will try again tomorrow.
    If i need to increase the tension is it simply a case of leveraging the tensioner body and then tightening the nut again ?
  4. poffo
    poffo Rookie
    Feb 8, 2023
    42
    graham nicholls
    Tazandjan,
    Looking at some earlier posts you offered, 126hz appears to be the original measurement, and the 335 - 360hz is the updated offering.
    would you deem 126hz as being incorrect now ?
    thanks
  5. tazandjan
    39,058
    Not incorrect, just the newer one is more consistent.
  6. fatbillybob
    Aug 10, 2002
    28,642
    socal
    Funny. I remember the frequency as the "middle Finger" as in frequency of middle F but I still do this incorrectly by feel. That's just the way I have always done it since the 308's
  7. Mirek
    Mirek Formula 3
    1,466
    Los Angeles, CA
    Mirek
    I wish the answer was 100% but I know from experience that it certainly is not…
    Anyway, what % of shops actually (and correctly) utilize such a tool ? Amidst a shop comeback following major service here in LA the owner claimed “nobody” he knew used them, “they were expensive” and if I could borrow one — from the mechanic that spotted their error (very loose belts !) — that “they would use it”.
    This was after my car was towed back to them a second time following my belt service/major. The worst $10k I spent overall. Venting now but still…just because a car has/had a major it means very little. I would prefer buying one running well “due” for a major. Any day. Every day.
    F456M likes this.
  8. tazandjan
    39,058
    Hopefully you found a new shop. A good tool can be had for around $250 and there are also apps for smart phones that work quite well.
  9. fatbillybob
    Aug 10, 2002
    28,642
    socal
    happens all the time…in the old days there was steager tensiometer to tension belts. In the early 80s I apprenticed as a Ferrari mechanic for a known Ferrari mechanic in LA. I got to know people in the industry and several FNA shops. I asked about steagers and not a single shop had one, not even FNA shops. I was curious to hold one in my hand.
    Mirek and F456M like this.
  10. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    652
    Continental Europe
    Didn't you mean to say instead that you had to depress the spring further to increase belt tension?
    Check this thread for a good discussion on timing belt tension.
    What tension did you measure on the short stretch of each belt, between the tensioner bearing and the lower cam drive?
  11. Rifledriver
    36,819
    Complete bull ****. Dealers were provided them by Ferrari. They had no choice in the matter. For years after all the independents I knew had them as well.
    I really do get it that you are the greatest mechanic of all time but you really do need to quit just making stuff up.
  12. Rifledriver
    36,819
    Also the use of Steager Gauges by Ferrari started in 1989. Electronic tensiometers started in 1999.
  13. poffo
    poffo Rookie
    Feb 8, 2023
    42
    graham nicholls
    Yes that is correct i had to make the belt tighter, which required pushing the pully towards the belt.
    I haven't done that yet, i had to do some work today, it will be the weekend when i get another chance to play with it, but i am there or thereabouts.
    thanks
  14. poffo
    poffo Rookie
    Feb 8, 2023
    42
    graham nicholls
    Evening,
    Put it all together this morning;
    Using the Gate Belt App i could get those numbers consistently.
    121hz and 230hz = 351hz on one side
    and
    111hz and 241hz = 352h on the other
    Alternator belt 118hz
    Water pump belt 101hz
    Thank you for your help.
    Timmo likes this.
  15. franschman
    franschman Formula Junior
    Dec 18, 2017
    362
    Holland
    Bart
    I'd never on any other car tensioned the cam belt(s) using the frequency method, but I was pleasantly surprised how easy, convenient and consistent it was. I had the help of my sister, who is a professional musician. On the first belt we had to practice a bit, but the second one was a 10 minute job. My sis just listened to my pinging and tapping and told me tight or loose, and she was only a few Hz off when we checked the final result with a sound meter.
  16. tazandjan
    39,058
    A perfect ear is a handy thing to have.
  17. Timmo
    Aug 26, 2017
    652
    Continental Europe
    @poffo , did you use an external mic plugged to your phone or the mic of the phone directly?
  18. poffo
    poffo Rookie
    Feb 8, 2023
    42
    graham nicholls
    No external mic, just held the phone as close to the belt as possible.
    I used both an I phone 8 and my son's 13 and they got the same recording.
    Car started and ran fine, but will need a longer run later this week.
    Timmo likes this.
  19. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,416
    San Carlos, CA
    Mitchell Le
    A girl with perfect pitch! Damn.
  20. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    Did this a few years back with gates app. Bought a cheap amazon mic for my iphone and clipped it on a bolt next to the belt. I got the idea from the guitar tuning apps on the iphone. If the iphone can tune a guitar, it can tune a belt.
  21. dodici
    dodici Karting
    Mar 24, 2007
    101
    Bay Area, CA.
    Dale
    I just grabbed an old acoustic guitar, placed it on a table near the front of the car, set two of the strings to the pitches (notes) I wanted, and pitch matched much as I would do if it were a musical instrument. Quite easy actually.
