Adjusting F40 Hood Pins | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Drew Altemara, Jan 3, 2012.
  1. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    How do you adjust the two pins that the front hood latches onto?
    One side has has more play than the other when latched. I thought I could just rotate the pin counter clock wise to raise it with a screw driver in the slot but it will not budge and I was afraid to put a lot of force on it until I understood how it worked. Is mine just stuck or do you have to remove the assembly to adjust?
    Could not find anything on this in the owners or service manual.
    Regards,
    Drew
  2. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    You need to loosen the nut below the spring under the rubber cover (I pulled the rubber cover up to remove it). I then needed to use a thin wrench because the spring gets in the way. I don't know if Ferrari has a special tool.
  3. Drew Altemara
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    Thanks Bill - makes sense.
    I was afraid to remove the rubber boot.
    Drew
  4. RHM
    RHM Rookie
    May 14, 2004
    8
    Disneylanda, Florida
    R.H.MESSERSCHMITT
    Hello Drew
    Thin wrench can be bought from bicycle store,there are used for the multi gear speed
    changer .
    R.H.M.
  5. Drew Altemara
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    Thanks guys. I actually had a cheap thin 13mm wrench that worked perfect to get to the nut. All is well on the hood front.
    Drew
