Adjusting front hood mechanism for easy closing? | FerrariChat
Discussion in '348/355' started by johan6504, Jun 2, 2007.
  1. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    Hi I am trying to figure out how to adjust the front hood mechanism on my new 355 GTS F1. My previous car closed very easy, by just dropping the hood it would close properly. On my new car I always have to push one of the sides to close completely. Have anyone tried to adjust the closing mechanism to solve this problem?
    And yes: the mechanism is properly greased so that is not the problem :)
  2. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    Do you close it from the middle? The hood on the F355 is quite light and not too stiff, so a good push in the center should make it latch on both sides.
    I used to just put it down and latch one side, and walk around to push the other corner. It get's annoying.
  3. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    Here's what I do on my 348 - it probably should apply to the 355 as well - I always close each side of the car separately. I put my palms astride each other on the section of hood just above the latch and push firmly down. Go to the other side and repeat. I never push from the leading edge of the hood or the center - I was told you can bend the metal there. I also don't drop the hood down.
    For the rear, i just gently close the trunk and again push firmly down on the trunk just above the latch.
    I was told to use this technique by a really knowledgeable guy here.
  4. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    Hi Guys
    I was told to drop it from the middle, it worked very well on my previous car but not on this one. That is why I want to know how to properly adjust the hood mechanism.
  5. bushwhacker
    bushwhacker In Memoriam
    May 25, 2006
    8,883
    Phoenix Az.
    Dennis
    Interesting?, sometimes I have a problem opening the hood. The left side opens fine but the right side seems not to release completely when the hood latch is pulled. I was told this may be due to a stretched cable since the latch is lubricated properly.
